location of the factory jack? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-12-2009, 10:41 AM
Din Din is offline
Din is starting off with a positive reputation.
2006 f250 , is it suppose to be behind the rear seat?
Old 09-12-2009, 10:51 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Yes it should be along with a case that contains the other stuff.
Old 09-12-2009, 10:59 AM
spinella's Avatar
spinella spinella is offline
spinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to behold
is there a difference w/ cab styles? my crew cab has the jack behind the rear seat and the rest of the stuff attached to the radiator shroud.
Old 09-12-2009, 11:02 AM
senix's Avatar
Quote:
For 2006 my F250 with all behind the seat.
Old 09-12-2009, 12:06 PM
rebelyell618's Avatar
rebelyell618 rebelyell618 is offline
rebelyell618 is starting off with a positive reputation.
must be a difference in the years because my '00 has the jack behind the seat and the tools under the hood (same as spinella).
Old 09-12-2009, 08:50 PM
Din Din is offline
I got shafted. Just got the truck few weeks ago, all i got was the tire iron and the rods to lower the tire down..
Anyone know the best place to get a replacement jack?
Old 09-12-2009, 09:31 PM
spinella's Avatar
try a junkyard.
Old 09-12-2009, 09:37 PM
if i was in your shoes i would just go find a good bottle jack, scissor jack, or if you have the room a small floor jack.
the factory jack isn't really the best quality jack for these heavy trucks, again that is just my opinion.
Im sure ebay or a local junkyard will have a replacement though if you want a factory piece. even rockauto or FTE parts guy could get you a replacement.
Old 09-13-2009, 12:07 AM
Pinky Demon's Avatar
Pinky Demon Pinky Demon is offline
Pinky Demon is gaining momentum as a positive member of FTE.Pinky Demon is gaining momentum as a positive member of FTE.
I have the jack behind the rear seat on my Crew, and the tools up front above the radiator.
Old 09-13-2009, 07:28 AM
CampD's Avatar
CampD CampD is offline
CampD is starting off with a positive reputation.
Get a craftsman 4 ton bottle jack, about the same size, goes up and down 10 times faster.
Old 09-13-2009, 07:34 AM
sandmanf250 sandmanf250 is offline
sandmanf250 is gaining momentum as a positive member of FTE.
make sure you have the adapter that is in the glove box or you won't be able to let your spare down. it fits on the end of your tire letdown rod.
Old 09-13-2009, 09:02 PM
Din Din is offline
thanks. i gotta look in the glove box make sure i have the adapter.
Old 09-13-2009, 09:25 PM
jake00's Avatar
jake00 jake00 is offline
FTE is my crack
jake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant future
my 04 had em near the rad. My 06 has em behind the seat
The prob with em by the rad is... I blew a tire while on a road trip. The tools were SOO DAMNED HOT, I practically burned my hands getting them out of there.
Old 12-04-2015, 10:48 AM
fordjacob fordjacob is offline
fordjacob is starting off with a positive reputation.
Exclamation 2015 Ford E450 RV chasssis
Where is the location of the factory jack on the 2015 E450 chassis? This is a 2015 Forest River sunseeker. With a 2015 E450 chassis.
Old 12-04-2015, 12:23 PM
-dave- -dave- is offline
-dave- is starting off with a positive reputation.
what is the factory jack rated to?
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
fdgdfgdf nmclella Testing..... 0 04-12-2015 06:23 PM
cgh lawdawg79 1999 to 2016 Super Duty 0 04-09-2015 09:04 PM
Brakes JBronco 1978 - 1996 Big Bronco 2 11-17-2001 06:23 AM
Tags
2003, 2005, 4x4, 99, duty, f150, f250, ford, jack, location, photo, spare, super, superduty, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
