Problem with turbo - F250 2006 Diesel - Ford Truck Enthusiasts Forums
Old 09-11-2009, 02:21 PM
bigtexan99 bigtexan99 is offline
bigtexan99 is gaining momentum as a positive member of FTE.bigtexan99 is gaining momentum as a positive member of FTE.
Asking for a friend:
Every time I tow my light weight travel trailer my check engine light comes on. Ford has to clean the turbos. It is still under warranty for a few more months but I see this as an expensive problem when the warrenty is up plus not having my truck for several days. Does anyone else have this problem?
Thanks!
Old 09-11-2009, 03:00 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Please ask your friend for the code he is getting. Also, does the truck sit for long periods between use? Normally this condition would be termed "lot rot" because the turbo rusts from lack of use and the veins stick. Also, how many miles on the engine?
Old 09-11-2009, 03:08 PM
90F250351 90F250351 is offline
90F250351 is starting off with a positive reputation.
my 05 just threw a code the other day after it took a 3000 mile trip across country. it was a P0299 - turbo charger underboost?
Old 09-11-2009, 03:26 PM
P0299 is a fault that sets when the difference between EP and commanded EP exceeds the limit for more than 30 seconds. It's caused by the following: Faulty EP sensor, VGT valve slow to respond, stuck VGT valve or a faulty PCM. EP being exhaust pressure. If your truck seems to be performing "OK" then it's probably from stuck turbo veins or a crapped up EBP sensor. It could also be caused by something your module is doing or commanding that the PCM doesn't like. Remove the module and see if the code returns. If the code doesn't return, use the module for a trotline weight and buy an SCT that won't trash your tranny.
Old 09-11-2009, 03:38 PM
i cleared the codes out last night and drove it with the module still in it and the light didnt come back on. I took the module out today b/c i had an appt at the dealer for them to look at it but they wouldnt let me leave it b/c the light isnt on anymore.
Old 05-22-2012, 10:47 AM
Liberty58 Liberty58 is offline
Liberty58 is starting off with a positive reputation.
I know this thread has not been active for a few years but I need to ask some questions. I too believe the turbo is dirty due to lack of use or sitting for long periods betweens use. Yesterday I was towing my trailer and the engine light came on so I continue to drive but after a short period the wrench light (limp mode) came up as well and I lost power to the turbo. I drove it for a 100 KM then shut it down. Restarted it after a 30 minutes and the wrench light went away and the turbo work ok. I pull and recreational trailer so it does not get a lot of use which I believe is not good for this engine. A diesel mechanic told me to see the truck if you don't run it often as you do more damage to it. I need a bigger truck to pull my trailer. I keep this truck stored in a dry garage when not being used. Is there anything I can do to keep this turbo cleaner when not being used? Is there anyway to clean or maintain this turbo?
Old 09-18-2012, 07:51 PM
C_H_M's Avatar
C_H_M C_H_M is offline
C_H_M is starting off with a positive reputation.
I have a very similar problem as described by Liberty58. Any other possible solutions other than paying the minimum $2500 to replace the poorly designed turbo?
Old 09-19-2012, 08:41 AM
Benchwrench's Avatar
Benchwrench Benchwrench is offline
Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.
if you're going to let the truck sit for long stretches I would recommend maintaining fresh oil with Rev-X additive and when it's in service, limit the idling durations and drive it like you stole it.
Old 09-19-2012, 02:06 PM
C_H_M's Avatar
Thanks BW, I was thinking the same thing about giving it a good workout whenever possible. I will try the REV-X too.
Old 09-19-2012, 02:14 PM
BPofMD's Avatar
BPofMD BPofMD is online now
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
The REV-X isn't really necessary either.... just use a good synthetic 5w-40.
Old 09-19-2012, 05:01 PM
Mich6.0 Mich6.0 is offline
Mich6.0 is starting off with a positive reputation.
If the truck sits the turbo will rust at the unisom ring and center section, Like other people have said drive the truck hard to break the rust, make the turbo go to full boost to cycle the vgt vanes to full movement. After the warranty runs out if you are mechanically inclined it will take you about 2hrs for the first removal and then the times come down fast as you get more proficaint
Old 09-19-2012, 09:01 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Quote:
I would scan it see what DTC come up
going to need a good scanner to pull wrench DTC if the CEL is on most scanners will pull that DTC
You need to also check BARO,MAP,EBP,MAF sensors as a bad one of those will mess with it
And Finally you can clean turbo instructions in tech folder
I used to not drive mine very often maybe every 2-3 weeks and let it warm up and then GIT ON IT make the Veins go threw the Full range motion a few WOT runs will do it if you dont have a Gauge if you do have a gauge you can watch VGT% and see the veins Move Basicaly (It has no Position sensor so FWIW but if runs Good then Odds are the Veins Move OK)
Old 09-20-2012, 01:54 PM
C_H_M's Avatar
First of all, many thanks to all the fine folks on this board that provide so much valuable information. I have been reading (there is a lot to read) as much as I can about the 6.0 and how to maintain and improve it.
Update on VGT:
Problem may be solved. Code was "turbo underboost". Dealer fix was replace the VGT with new improved version that does not rust. $2500. I was reading many of the issues on this forum and yesterday I decided to try a EGR disconnect. Wow! I have a new truck.
Prior to disconnect the turbo psi would only boost if I went full throttle and then it took 4.5 seconds to engage. The power always felt like a snail in mud and fuel economy was 13.4 best possible.
After disconnect, the psi gauge shows some involvement at all speeds and bounces to 30 psi at full throttle with only a very slight delay. The truck is very responsive and calculated MPG is 15.4 at 65 mph. It seems like this diesel/vgt combo was designed and built to run this way, and that maybe the EGR setup was an after thought to meet epa standards. Anyway, I have a totally different truck right now, and time will tell if this is a permanent fix.
I hope it is ok that I did not post this in the rather massive EGR thread, as I thought it was applicable to this discussion.
One disclosure that may have affected the large prior and current performance differential is that I have 35 inch tires but the speedo and shift points were adjusted by the dealer.
Old 09-20-2012, 02:24 PM
I don't know if you have an SCT but if you get one you'll like your truck that much more.
Old 09-20-2012, 03:20 PM
Canadianpowerstroke's Avatar
Canadianpowerstroke Canadianpowerstroke is offline
Canadianpowerstroke is starting off with a positive reputation.
Update on VGT:
CHM what did you do for a EGR Disconnect did you just unplug from the EGR Valve
need help new diesel owner problems with turbo f250jowssh 6.0L Power Stroke Diesel 12 03-25-2015 02:48 AM
Loss of power chrisjfontenot 6.0L Power Stroke Diesel 1 08-30-2012 05:08 PM
Need Help: Found Water in Turbo kchartier 6.0L Power Stroke Diesel 15 01-11-2011 12:49 PM
Turbo Noise?? kpmurfy15 6.0L Power Stroke Diesel 5 03-20-2008 09:01 PM
Turbo Fault Code SZMatters 6.0L Power Stroke Diesel 28 06-09-2004 07:59 AM
Tags
2005, 2006, 250, check, desiel, diesel, engine, f250, ford, light, location, problems, truck, turbo, vgt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
