Problem with turbo - F250 2006 Diesel - Page 2 - Ford Truck Enthusiasts Forums
Old 09-20-2012, 04:43 PM
C_H_M's Avatar
C_H_M C_H_M is offline
C_H_M is starting off with a positive reputation.
I just unplugged it as outlined in the Tech Folder on this site.
Still researching if I need to do any tuning etc... based on how I use it.
About 100 miles since the disconnect, no CEL or DTCs.
Old 09-20-2012, 06:43 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Quote:
Originally Posted by C_H_M View Post
First of all, many thanks to all the fine folks on this board that provide so much valuable information. I have been reading (there is a lot to read) as much as I can about the 6.0 and how to maintain and improve it.
Update on VGT:
Problem may be solved. Code was "turbo underboost". Dealer fix was replace the VGT with new improved version that does not rust. $2500. I was reading many of the issues on this forum and yesterday I decided to try a EGR disconnect. Wow! I have a new truck.
Prior to disconnect the turbo psi would only boost if I went full throttle and then it took 4.5 seconds to engage. The power always felt like a snail in mud and fuel economy was 13.4 best possible.
After disconnect, the psi gauge shows some involvement at all speeds and bounces to 30 psi at full throttle with only a very slight delay. The truck is very responsive and calculated MPG is 15.4 at 65 mph. It seems like this diesel/vgt combo was designed and built to run this way, and that maybe the EGR setup was an after thought to meet epa standards. Anyway, I have a totally different truck right now, and time will tell if this is a permanent fix.
I hope it is ok that I did not post this in the rather massive EGR thread, as I thought it was applicable to this discussion.
One disclosure that may have affected the large prior and current performance differential is that I have 35 inch tires but the speedo and shift points were adjusted by the dealer.
New VGT $2500? WHAT?
Old 09-20-2012, 10:40 PM
Benchwrench's Avatar
Benchwrench Benchwrench is offline
Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.
I think new VGT stands for; they installed a new turbo to the tune of 2500 bucks.
Old 09-21-2012, 12:34 PM
C_H_M's Avatar
$2500 was the estimate for a new turbo. I declined and did the disconnect, and it seemed to take care of the problem with the turbo.
Old 09-21-2012, 04:02 PM
TexasA&M's Avatar
TexasA&M TexasA&M is offline
TexasA&M is gaining momentum as a positive member of FTE.TexasA&M is gaining momentum as a positive member of FTE.
If all you did was disconnect the EGR, you're going to have problems with your engine fan. I'm not sure how they are tied together, but they somehow share a signal. It's best to turn your EGR off with a tuner, which will allow proper functionality of the engine fan.
Old 09-21-2012, 06:13 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Quote:
Agreed^^^^
Or do a Proper EGR Deleate kit
$$2500.00 for a Turbo is STRAIGHT UP THEFT
Old 09-21-2012, 06:26 PM
I would like to know what they did to prevent rust. Maybe vane sweep flash.
Old 09-21-2012, 07:18 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
"A Revised Machined Recess Turbocharger (5c3z-6k682-ca) Designed Exclusively To Address Corrosion Related Turbocharger Performance Is Now Available In Service."
Old 09-22-2012, 01:12 PM
blowin_smoke_1977's Avatar
blowin_smoke_1977 blowin_smoke_1977 is offline
blowin_smoke_1977 is starting off with a positive reputation.
I, too, have a similar issue. After tearing the top end down and doing both complete head overhauls, new head gaskets, head studs, EGR delete and oil cooler update I am having the dreaded turbo overpressure issue while throwing the P0299 underpressure code. I completely cleaned and lubed the turbo when I had it out, so I didnt think that was the issue. But searching the P0299 issue I decided "What the hell" and tore it out again to be sure. What did I find when I pulled the turbo? Nothing. Vanes are perfect, unison ring slides like greased lightning, and the removal of the inspection plug revealed that everything was good. There was some oil in the housing that I figure is the result of serious overpressure because it originates from around the spindle shaft. BTW, should I rebuild the turbo and replace the seals at this point to prevent runaway or further damage? Anyway, I also took out the MAP sensor and it was caked up like hell. Sonic ceaning it now. Would that cause the VGT valve to act erratically, or be a slow/no respond? This thing has absolutely crappy throttle response right now, very little low end, very lackluster mid band, and top end.... forget it. Sounds like a broken gas main driving by though. And where is the EBP sensor on the `04 models? I want to pull it and check it too.
On a seperate issue it is also throwing code P0282 - Injector Circuit Low #8 Cylinder, and P1000 - Monitor Checks Not Complete. Pulling the #8 cylinder injector harness while running causes the #8 cylinder to drop, so I know the inject is working, at least to some degree.
Van Turbo wheel comadvan 1999 - 2003 7.3L Power Stroke Diesel 6 08-17-2016 12:20 PM
need help new diesel owner problems with turbo f250jowssh 6.0L Power Stroke Diesel 12 03-25-2015 02:48 AM
garret stage 1 turbo 93truck 6.0L Power Stroke Diesel 0 12-26-2014 04:54 PM
What can cause my turbo to keep failing? ssyputa 1999 to 2016 Super Duty 7 08-18-2014 01:46 PM
Loss of power chrisjfontenot 6.0L Power Stroke Diesel 1 08-30-2012 05:08 PM
Tags
2005, 2006, 250, check, desiel, diesel, engine, f250, ford, light, location, problems, truck, turbo, vgt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
