4.9L oil pan gasket replacement help...
Old 09-11-2009, 12:20 PM
jesterdog's Avatar
jesterdog
jesterdog is offline
I have a 1994 F-150 4.9L and I need to replace the oil pan gasket.
Has anyone done it?
What is involved? How hard is the job?
Got any pics?
Thanks!!!
Old 09-11-2009, 12:35 PM
andym's Avatar
andym
andym is offline
No pics, but it's pretty easy. Unbolt the pan, remove the old gasket, buy a felpro one-piece gasket (not the four-piece cork/rubber one) and put it in.
You don't have to raise the engine as some will claim.
Old 09-11-2009, 01:18 PM
cabloom300's Avatar
cabloom300
cabloom300 is offline
Heck i might put mine in the, i bought a gasket and found out how much work it would be and people i talked to said it wouldnt be worth it cause the pan hits the cross member so u have to pick the motor up a bit. this isnt the case?
Old 09-11-2009, 01:22 PM
nstueve's Avatar
nstueve
nstueve is offline
I will say that I have done it both ways... On my F-150 it was way easier to lift the engine... I was also removing the pan to replace the oil pump and screen. It is a tight fit to not lift the engine but you can do it. I agree with andym get the one piece felpro it will contain 4 small pins in the case.
If you want to pull the engine up...
1.) Take the 2 motor mount bolts out. one on either side at the bottom of the engine compartment.
2.) hook engine hoist to front engine hook and pull the entire engine and drive train up. I am sure you can detach more but this will get you a couple extra inches.
3.) drain the oil
4.) remove all the oil pan bolts and metal bars underneath them.
5.) drop pan and remove old seal.
6.) put new seal into place (remember you have to wrap this under your oil screen and pump inside the pan to get it all the way around and into place)
7.) use the screw in pins to hold the gasket and pan into place
8.) start your bolts back in all the holes but the 4 that have the pins in them.
9.) remove the pins, put last 4 bolts in and tighten evenly all the way around.
10.) bolt the engine back down and fill with oil... you're done!
The first time I did mine was on a 2wd 1992 and it was a pain in the *** to not lift the engine! You can get by without doing it but I believe it is way easier to lift the motor on a F-150 2wd. I could do it on my F-250 4x4 without doing the engine hoist. You can get it done without lifting on either its just kinda a pain because it's a tight space to work in. lifting the engine just makes it easier. Also you might want to consider replacing your pump/screen if you are going to go to all the trouble of changing out the gasket. It's not that hard to do yourself it is just time consuming working around the cross members under the truck. If you are mechanically inclined I can't imagine that it would take much more than 2hrs... Kinda depends on how much you want to do... If you change the pump and screen, if you lift the engine, if you take the pan out to clean it... After doing 7 of them (4 on the 300 I6's)... I could probably get it all done in 1.5-2 hrs...
Old 09-11-2009, 03:29 PM
jesterdog's Avatar
jesterdog
Thanks, guys. You've been very helpful as usual!!!
Old 09-11-2009, 03:31 PM
andym's Avatar
andym
andym is offline
If you are just replacing the gasket you do not need to lift the engine. I have done it on both 2wd and 4wd trucks and it's not that hard. Last time I did it, I think it took an hour and a half.
If you need to replace the pump and pickup screen, then you will have to lift the motor. But since there is so much more work involved it's silly to replace those parts if they are working fine.
Old 09-11-2009, 03:33 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
if taking out the pan he left out:
drive truck up on ramps
remove negative cable
remove shroud bolts and set it on fan
the trans mount needs to be unbolted and tran.s jacked up
drop screen and pump in pan
Old 09-12-2009, 05:38 AM
Whoudini74's Avatar
Whoudini74
Whoudini74 is offline
Great info guys, I just found out that my oil pan gasket has a crack in it, not dropping too much oil, maybe a drop or two after I've shut the truck down, but this saves me from asking the same question about replacing the gasket.
Old 09-12-2009, 06:02 AM
Volvo92906's Avatar
Volvo92906
Volvo92906 is offline
Andym, so if you do not remove the pan does that mean you need to unbolt it and "drop" it and run the gasket through and under/around the pickup tube to get it on all four sides of the pan and then raise it back up?
Mine doesnt need replacing now but its not looking too good and I didnt want to have to mess with what Haynes says....
Old 09-12-2009, 10:54 AM
quicklook2's Avatar
quicklook2
to do only the gasket, that is correct.
plus cleaning off the old gasket without getting crap in the pan.
Old 10-01-2009, 05:48 PM
mrblonde108's Avatar
mrblonde108
mrblonde108 is offline
i don't know
I have a 93 with 4x4 300ci and speed manual i tried to get the pan out without jacking engine up and i couldn't.
Old 10-01-2009, 05:56 PM
mrblonde108
one more thing
i didn't get pan out yet i need to pick up my jacks but is it ok to lift engine up by jacking on crankshaft pully??
Old 10-01-2009, 06:22 PM
Volvo92906's Avatar
Volvo92906
NO!!!! I believe you get a piece of wood and put it under the engine, jack it up, then stick some wood blocks between the engine mounts and the frame to keep the engine supported on.
Old 10-01-2009, 06:33 PM
mrblonde108
i was going to use a piece of wood under the crankshaft but yeah good idea i'll jack it up under the oil pan and then use wood like u said. damn oil pan rusted out.
Old 10-10-2009, 04:16 PM
mrblonde108
Hey just an undate. finally got the pan down pain inn the ***.Transmission bolt havd to be removed and tranny jacked up but hope i didn't break anything. Slave cylinder is up against body. Engine has to be jacked up. But the biggest pain in the *** is the damn windshield wiper motor the whole cowl has to come off to get that out. Motor has to be removed to get engine high enough or egr valve hits it. I bent the thing a little to get at the bolts. Still a pain. Now i have to get the gasket a put it back in. This is a 93 with a 300 six and 5 speed manual.
Thanks Everyone
Peace
Quick Reply: 4.9L oil pan gasket replacement help...
