Does anyone have an EVTM for the '93-96 F-series? I am working on a conversion and I need copies of the three connectors that plug into the cluster. Well actually two plug into the cluster and one plugs into the speedo.
I would buy the evtm but i am going to yank the motor and put it into my '71.
Hey subford, would these be the same for my 95 F-150 4wd? My temp gauge isn't working and I changed the sending unit and was wondering if it could be the connection at the cluster or the gauge itself. Thanks!
Thank you so much for the pinout diagram. This will help with my conversion. There is one more pinout diagram for the plug that plugs into the speedometer. You wouldn't by chance have the pinout diagram for this one would you?
