obdll scanner
on
Pros: GUI is very easy to use and understand, for the 6.0 it pulls codes from 9 modules that are available on our computer and you can pull sensor readings as well, you can initiate system tests and programming on certain modules. Buzz test, GEM reprogram etc. Lastly considering all that it can do, it is very much a bargain. Just pulling codes a few times and you'll have it paid for versus having to go to the dealership.
Cons: To me the only con is dependent on the size of the laptop you use.
Our trucks are OBD-II Non-Compliant. What you need is something that will read the CAN protocol. AutoEnginuity will read it, it is one of the programs that I use and the one I would recommend for people here. You will have to get the Ford License for it as well, otherwise it won't read diesels at all due to that OBD-II non-compliant.
on
Not a problem. If you like messing around with your vehicles, in my opinion a program like this is needed, even moreso with the later vehicles and the more sophisticated computers that are on those.
on
03 was a transition period between 7.3 and 6.0, that's probably why they only listed 04-08(technically speaking I think it's 07 really for 6.0). They do support the 7.3 engine as well, so I cannot logically think of a reason why it wouldn't support an 03 6.0. More then likely just a typo on their part.
on
It allows for some things along those lines. I would actually have to have it hooked up to the truck to know what all it allowed. It will vary between vehicles as well. Only thing that I have done so far is GEM programming and the injector buzz testing.
