93 F350 Crewcab suspension improvements?
I heard of the front shackel conversion but can't find any details on it and I need to remove a bunch of extra leafs the prev owner added (1 in front and 3 from the back). What can I do to make the truck ride better? If I loose a lot of height by removing the extra springs should I have the old ones re-bent or buy new ones?
It's a F350 it is supposed to ride stiff. I have a '92 F350 4x4 I know exactly what you are talking about, but it is a heavy duty truck. You should not lose much if any height when removing the extra springs the PO installed. The cheapest way to make your truck ride better is adding ~750 lbs. of weight in the bed.
Thanks for the responses. I don't plan to offroad much but need to be able to do some when I go camping or hunting. Mainly I just need to tame it a bit so it is able to soak up bumps. There are 8 total leafs in the rear and 3 total in the front and there are older bilstein shocks (2 per axle) with a rancho steering stablizer (?) that is horizontal on the front axle.
Yes. it is called a Reverse Shackle Kit(RSK) Off Road Unlimited(ORU) and SKY manufacturing make them. They add approx 2.5" of lift and make one hell of a ride improvement!
The best way to get lift and ride is us SD springs and a RSK to relocate the front spring hangers. Then you will have the ride of a SD! And rear SD springs bolt right in place of the stock springs, all you have to do is drill out the front hanger for the larger spring bolt
I had one in my 97 F350 and i have on in my 96 w 4" lift springs in the front and 6" springs in the back
here is my 97 w stock springs, RSK in the front. Stock spings in the rear w a 5" block in place of the stock 4"
<a href="http://s108.photobucket.com/albums/n29/diesel_brad/?action=view¤t=img004.jpg" target="_blank"><img src="http://i108.photobucket.com/albums/n29/diesel_brad/img004.jpg" border="0" alt="Photobucket"></a>
here is the 96 w the RSk and 4" font fit springs and 6" rear springs w a fitted add-a-leaf
<a href="http://s108.photobucket.com/albums/n29/diesel_brad/?action=view¤t=000_0028.jpg" target="_blank"><img src="http://i108.photobucket.com/albums/n29/diesel_brad/000_0028.jpg" border="0" alt="Photobucket"></a>
Those trucks are badass!!!! I found this RSK that is a little cheaper http://www.sky-manufacturing.com/new...uct.php?id=162
But where do I get the SD springs and do I get them for both the front and back or just the front?
A common SD front spring is the "X" code for some lift a"V" code for a stock spring height. You do not need to put SD springs in the rear but you will get a better ride w both of them swapped. Another common thing to do is put SD Icon rear 5" lift springs in and do away w the factory rear block.
As for finding SD springs you can go to your local 4x4 shop and see if they have any stock SD springs from a lift they installed, Or a JY, Or you can go to ford and buy them new. ......O yeah the "B" codes are the best ridding rear ones
