Silverstar Ultra's ?
They wouldn't, but you can get better bulbs than that. Get a 100/90W Narva or Xtravision instead. Silverstars are actually dimmer than their conventional counterparts. The Silverstars use a coating which removes some of the yellow light, causing the bulbs to appear to have a whiter light. The whiter light appears to be brighter because of the way our eyes perceive it, but dimmer is still dimmer. A silverstar of a given wattage will be dimmer than a conventional halogen of the same wattage and filament type.
To get the most out of whatever bulb you use, you need a headlight relay kit, which provides the bulbs with more useful power. Its not your lenses I would worry about, its your stock wiring. The relays bypass the undersized stock wiring and reduce the stress of your headlight switch and multifunction switch.
I have the siverstar ultras and what bear river said i'm not going to bash but the light does seem like it's brighter. I've had physics classes and I remember them stating the color of light that is best for the eyes, it isn't yellow or white but it's blue or green or something due to the wave lengths. i see them as being a cleaner looking light, yellow seems drab to me.
anyways they won't damage your original lenses. if you are looking for high performance bulbs and re-wiring, could try to find a kit for HID. They use a ballast and different type of bulb instead of the traditional halogen. brother had them on his gto and they were brighter but there is no hi-beams.
Its amazing that Sylvania and others can pull the wool over everyones eyes. Silverstars probably are brighter than most stock bulbs, but they are still not as bright as an uncoated bulb with a similar wattage and filament. The Sylvania Xtravision is not only cheaper than a Silverstar, it is brighter. Its almost exact same thing, except the Xtravision does not have the color filter. You can get brighter halogens than the Xtravisions. The trick is your wiring needs to be able to support the brighter bulbs.
The Crystal visions are the same problem. Blue light is not good for night driving. It blinds other drivers and impairs your own night vision.
Upgrade to a higher wattage uncoated halogen, aim the lenses properly, and upgrade your wiring. I've done it, and I have a worse headlight than yours. (Aerostars have a poor beam pattern). No bulb will fix the poor pattern, but going with some offish color color screened bulb will not improve your visibility. Also do some reading and educate yourself about headlights. Educate yourself about the effects of different light colors, the pros and cons, etc. Then we can move away from this BS opinion and get to the facts.
Want to know the truth about automotive lighting, read the technical articles at
www.danielsternlighting.com
Future_LEO
1999 to 2016 Super Duty
09-06-2021 01:11 PM
hd4ever
03-14-2008 06:53 PM
bulbs, color, crystal, crystalvision, f150, ford, headlights, night, philips, silver, silverstar, star, sylvania, ultra, vision
