F250 Fan heater won't work ? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-10-2009, 09:02 AM
racingxr racingxr is offline
racingxr is starting off with a positive reputation.
Hi,
I have a F250 2005 6.0L Diesel 158000km.
The fan heater stop working at any position (1-4).
Any ideas ? Where should I look ?
Thanks !
Martin Mailloux
Old 09-10-2009, 09:29 AM
12ozd's Avatar
12ozd 12ozd is offline
12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold
I would start w/ the fuse.
Old 09-10-2009, 09:33 AM
Already try that, but that's not it.
Thanks !
Old 09-10-2009, 09:41 AM
12ozd's Avatar
EATC or manual?
There is a blower motor relay in the battery junction box.
Old 09-10-2009, 10:14 AM
Automatic transmission.
Where is this relay ?
Old 09-10-2009, 10:22 AM
12ozd's Avatar
Sorry,I was asking EATC (electronic automatic temp.control) or manual
the relay is in the battery junction box
Same place you checked your fuse. (1.2)
IIRC the relay on the top row,2nd from left.
Double check your owners manual.(if you have one)
Old 09-10-2009, 11:47 AM
Thanks !
I'll try that and let you know...
Old 09-17-2009, 11:47 AM
Check the fuse and relay.... but it's not it...
Any ideas ?
Could it be the fan clutch ?
Old 09-17-2009, 01:38 PM
12ozd's Avatar
Check for voltage at the fan motor.
Motor could be bad.
Oil in coolant reservoir and intermittent engine light eric_dean_martin 6.0L Power Stroke Diesel 6 01-31-2016 07:38 AM
Doorpanel trim martinkik 1967 - 1972 F-100 & Larger F-Series Trucks 9 01-07-2016 03:51 PM
Trustworthy/ reccomended shops in the DC area Martin97C5LS1 1999 to 2016 Super Duty 0 04-23-2015 11:33 AM
OIL winter F150 2006 SwedMartin Oil & Lubrication 2 08-19-2014 09:51 AM
New member/owner F-350 xlt Sxeautoworx New Member Introductions 2 03-07-2014 08:04 AM
Tags
2004, 2006, duty, f150, f250, fan, ford, fuse, heater, located, motor, relay, stop, super, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
