Transmission Fluid Capacity - Ford Truck Enthusiasts Forums
Old 09-10-2009, 09:27 AM
cworley250sd cworley250sd is offline
cworley250sd is starting off with a positive reputation.
I am working on a 1994 F-150 with E40D Transmission, I just did a filter change and need to know how much fluid to put in.
Chris
Old 09-10-2009, 09:45 AM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
if it's anything like my F-250 5 spd... You have a plug on the side where you can fit the square end of a rachet in to take out (on the side of the tranny). once you take the plug out fill the tranny until a little drains back out the plug hole... put the plug back in and your done... you can also call ford for the exact E40D amount... my ZF-542 took 4-5 qts
Old 09-10-2009, 10:44 AM
CS45's Avatar
CS45 CS45 is offline
CS45 is starting off with a positive reputation.
Um, Dude. You're talking about a manual vs an automatic here. The E4OD is an automatic transmission.
Depending on if you drained the Torque Convertor, which holds the majority of the fluid, you can get up to 18 ltrs into that tranny (mine took just over 17). Capacity is listed in the back of your owners manual, if in doubt.
Hope this helps.
CS45
Old 09-10-2009, 10:47 AM
nstueve's Avatar
oops! my bad! Good catch CS45!
Transmission Fluid Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 2 04-03-2016 03:12 PM
recommended power steering fluid for f150 waskin27 General Automotive Discussion 1 07-01-2013 12:21 AM
power steering fluid or trans. fluid abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 4 04-16-2013 06:36 PM
transmission fluid change interval? ZonaNavyStar 1999 to 2016 Super Duty 6 10-30-2009 01:35 PM
help-- transmission fluid tag187 1999 - 2003 7.3L Power Stroke Diesel 1 07-19-2008 10:02 PM
Tags
1996, 2001, 2003, 2009, 94, atf, capacities, capacity, change, f150, f250, fluid, ford, oil, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
