Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-10-2009, 08:00 AM
F250army45d F250army45d is offline
F250army45d is starting off with a positive reputation.
Np542
Does any one know where I can buy a NP542 5 speed to bolt to an FE engine? I want to put a five speed into my 77 hiboy and am having trouble locating one.
__________________
Mikes Trucks
77 F250 4x4 Highboy FE410
78 F250 4x4 Flatbed 351M to 385
97 F150 4x4 Shortbed 4.2L V6
  #2 (permalink)
Old 09-10-2009, 01:28 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
What was the original application? I searched for this trans and did not find a lot, other than parts. Seems like it was used by several mfgs, but it's for mediums, correct? That means clutch and pilot bearing issues, as the input shafts tend to get larger as you go up the food chain.
The NV4500 seems to be easily available, and adaptors are available.
http://www.high-impact.net/transmiss...ear/nv4500.htm
  #3 (permalink)
Old 09-10-2009, 05:17 PM
It was used by many MFG but could be found in F500 F600 I think but medium duty trucks is correct. I would like to find a five speed to bolt to a FE in my highboy it could be a clarck I have started searching them as well.
__________________
Mikes Trucks
  #4 (permalink)
Old 09-10-2009, 06:10 PM
Dino has posted some info on adapting a Clark. Many are not OD, if you are looking for OD.
Not sure on the NP542. NV4500 is OD.
I'll see if I can find the Clark post from Dino.
  #5 (permalink)
Old 09-10-2009, 06:32 PM
OK, that didn't take long:
http://www.ford-trucks.com/forums/58...d-a-391ft.html
http://www.ford-trucks.com/forums/26...e-511-a-2.html
There's more but that ought to do.
  #6 (permalink)
Old 09-11-2009, 03:07 AM
Thanks for the information I think I may look at changing some of the gears in the NP435 to see if that helps get better fuel milage and lower RPM ranges. I saw NP435 offered for different makes of vehicles offered different gear ranges. make first 4.56 currently it is 6.68 make second 2.29 currently 3.34 third 1.74 make 1.31 and fourth would be 1.0 and take reverse from 8.26 to 6.60 does this sound like a reasonable Idea? I think swapping in some different gears in the diffs may help currently running 4.11? Any thoughts please because my five speed Idea isn't going far. I have give thought to a bolt on over drive but because it is four wheel drive it cause other issues.
__________________
Mikes Trucks
  #7 (permalink)
Old 09-11-2009, 02:34 PM
Some specific info on the NP435:
http://www.novak-adapt.com/knowledge/np435.htm
Not sure about changing gear sets in a trans like that--might be easier to just find a good one in the ratios you like. Looks like just two ratios for Ford. Can you change the gear sets without changing the input/output shafts?
The link I gave you for the NV4500 also has the "Ranger OD". It fits between the bell and trans. You have to move the trans and TC back, so there will also be DS issues.
As for overall ratios and what axle gear you could change to and still have a good overall set up, the Novak site has calculators. Click on 'gearing', you need your tire size also.
BTW, you say '77 for the model year of your truck. Sure you have an FE, not a 400 or 351M. I thought the last year for the FE was '76
  #8 (permalink)
Old 09-12-2009, 08:13 PM
rebocardo rebocardo is offline
rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold rebocardo is a splendid one to behold
I know in the 67-72 forum there was talk about the Clark 5 speed behind a FT being used on the FE, but, they were still a 1:1 in 5th gear. I don't know exactly what they weight, but, they seemed to me to be about 2x the size of a NP435.
__________________
The Year 2009 Anno Domini -
May it bring a great year of Revelations to you.
  #9 (permalink)
Old 09-13-2009, 04:44 AM
It was factory 400 but previous owner swapped in a 410 FE.
__________________
Mikes Trucks
  #10 (permalink)
Old 09-14-2009, 11:33 PM
bghnkinf250 bghnkinf250 is offline
1986 Ford F-250
bghnkinf250 is gaining momentum as a positive member of FTE.
Is it married or divorced TC? Some of the NP 540 series were OD, but it will just take some searching to find the right one. Even if you swap the NP 435 for one with different ratios, you still have 1:1 high gear ratio. If you change the ratios in the axles, you are looking at more money...how much gas savings will you get after $1000 or more to change the ratios. I would take my time to find the OD medium duty truck one, BUT they are only 2wd.
__________________
"A man does what he must - in spite of personal consequences, in spite of obstacles and dangers and pressures - and that is the basis of all human morality."
  #11 (permalink)
Old 09-15-2009, 05:22 AM
Well I had never given thought to the shafts that I would have to look into. But yeah it is divorced TC thas why I figured I could bolt a five speed in easier and started searching for a NP542 I heard it would bolt directly into my truck. Well I have not priced gears yet but if I do what would I want really?
__________________
Mikes Trucks
  #12 (permalink)
Old 10-29-2009, 08:12 PM
Ranger Torque Splitter For 1971-87 4-Speeds
Any one know any thing about these units?
__________________
Mikes Trucks
Tags
542 , 77 , f250 , gear , np , np435 , np542 , ratios , speed , trans , transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
