leaky injectors on a 6.9
Old 09-09-2009, 09:11 PM
daw00l's Avatar
daw00l
daw00l is offline
i have an'86 ford f-250 with a 6.9l diesel engine. One of the injectors is leaking fuel. I replaced the O rings in the injector and it still leaked. then i sort of jiggle one of the other ones and it started leaking too. Do i need to replace the whole injector?
Thanks
Old 09-09-2009, 11:00 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
daw00l,
Welcome to FTE and the IDI diesel forum.
Where is the fuel leaking at?
Is the fuel line nut tight?
Or is the fuel leaking out down below the return line Tee?
If below the Tee, you need a new injector.
Old 09-09-2009, 11:20 PM
daw00l's Avatar
daw00l
daw00l is offline
yes, it is leaking from below the tee, in between the plastic tee and the rest of the injector. The o rings i replaced were inside the tee, and they didn't help at all.
Chris DeLoache
09-20-2016 10:07 PM
eightball8
12-08-2015 12:30 PM
Philip Holwell
13
01-28-2013 08:52 PM
timb1776
15
06-01-2012 04:37 AM
charleslincoln
09-09-2011 12:33 AM
Quick Reply: leaky injectors on a 6.9
