Door hinge bushing replacement?? - Ford Truck Enthusiasts Forums
Old 09-09-2009, 08:21 PM
alconk alconk is offline
alconk is starting off with a positive reputation.
My left door is getting harder and harder to shut and come to find out I think the hinge bushings are shot. I can lift the door up and down abit so is this something the average DIY can do or do you need special equipment?
Old 09-09-2009, 08:31 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
You need to replace you hinge pins/bushings. You should be able to get them at any local parts store. You'll have to take off your hinges to replace the pins and bushings. Detail instructions come with the replacements. A grinder, small vice and a hammer is about all you need. I did mine without ever doing it before and was able to do it just fine. And unless you replace the hinge pins, you won't be able to get your door adjusted worth a damn to shut nice.
Old 09-09-2009, 11:33 PM
Are the kits per application or are they universal?
Any tips for door hinge rebuild? Uni Moe 1967 - 1972 F-100 & Larger F-Series Trucks 13 03-27-2014 07:10 PM
Saggy door Island'r 1987 - 1996 F150 & Larger F-Series Trucks 8 02-05-2014 08:43 AM
1998 f250 Door Hinge Pin and Bushing Kit Darryl 123 1997 - 2003 F150 1 04-07-2011 11:01 AM
pins & bushings or hinge?? bcaughhorn 1999 - 2003 7.3L Power Stroke Diesel 7 12-26-2010 09:46 AM
Hinge pin replacement 93 F250 pjckm 1987 - 1996 F150 & Larger F-Series Trucks 1 08-17-2006 09:52 PM
Tags
79, 97, bushes, bushing, door, f150, find, ford, hinge, hinges, pin, replace, replacement, truck, trucksdoor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
