Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 09-09-2009, 07:51 PM
clearnetedm clearnetedm is offline
Garage is empty, add now
clearnetedm is starting off with a positive reputation.
Weight Distribution Hitch Needed?
Hey Guys. Just looking for your thoughts on wether or not a weight distribution hitch (WDH) is required for my ride. I'm going to be towing a 25' travel trailer dual axle. The tongue weight is about 500Lbs and the trailer weight is around 5000-5500Lbs. I'll be a seasonal driver maybe 3 - 4 times a year. The dealer indicated I wouldn't need a WDH as this trailer is light and the dual axle will provide a low tongue weight and good balance. He mentioned something quick about the EXPY independent suspension handles a little better with load, but I don't think that plays much here.
I will be towing with a 2008 EXPY EL Limited, no air bags.
I appreciate your comments.
  #2 (permalink)
Old 09-09-2009, 08:49 PM
eddiemoney eddiemoney is offline
eddiemoney is starting off with a positive reputation.
You are definitely within specs of any expedition with the tow package. Will it hurt to have a WDH, no, but for the use you are stating I don't think you need it. Does the trailer have brakes? If so you may consider a controller, there are a bunch that are plug and play.
  #3 (permalink)
Old 09-10-2009, 12:01 AM
rebelyell618's Avatar
rebelyell618 rebelyell618 is offline
rebelyell618 is starting off with a positive reputation.
i would go with a WD hitch just for the fact you can add a actual working sway controller system to it when youre towing in windy conditions. Plus if the WD hitch is set up right then it is safer for you and the people around you than if you just had to hooked up a drop mount.
I think even with a 500lb tounge weight your ride is going to be sitting a bit low and the WD hitch can fix that, plus make the ride a bit more enjoyable.
that trailer will have brakes and you will need a trailer brake controller.
__________________
Eric
2000 Ford F-250 Crewcab Shortbed 4X4 5.4, 4.10 gears
stock height (for NOW), T3 grille guard with hella lights, cherrybomb extreme muffler, cb and satellite radios, many minor mods with more be putting on everyday.
  #4 (permalink)
Old 09-10-2009, 12:40 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
simply put...no
and no, the Expy won't really notice the 500 lbs tongue wieght. It is a 8 passenger vehicle and has the rear springs to hold that sort of weight.
I'm 280lbs myself and my EL Limited doesn't even squat a tiny bit under my weight when I crawl into the rear.
Hopefully the trailer has e-brakes...at least surge brakes at the very least.
a WD hitch would be nice...but not for that weight. and a Brake controller would be nice if possible
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #5 (permalink)
Old 09-10-2009, 06:59 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Your dealer is full of it!
You need a WDH with the soft coil spring suspension of the Expedition. And your 5000 pound trailer should have a MINIMUM of 500 pounds on the ball for safe towing. 10% to 15% is the requirement. Our 5000 pound trailer puts 750 pounds on the ball when we're carrying a full load of freshwater.
A 1000/10,000 pound Equalizer (tm) is my recommendation. This WDH has built in sway control.
Click the image to open in full size.
I assume you have a brake controller? Tekonsha Prodigy or P3 are state of the art and not expensive.
-- Chuck
  #6 (permalink)
Old 09-10-2009, 08:23 AM
Very nice, thanks guys. I'm concluding that the WDH isn't something you need to tow this but will certainly help for increases safety and support. The trailer is actually rated at 505 Lbs at the tongue dry so I would assume 505-650 LBS with gear and water?? I don't yet have a brake controller but yes this trailer does have electric brakes. I was just going to get he dealer to install something common for that, but perhaps I should shop around.
Chuck, have you ever towed your rig without the WDH? Your's looks similar to what we are getting and wonder what your experience is with our without.
Thanks again all.
  #7 (permalink)
Old 09-10-2009, 09:52 PM
hookd's Avatar
hookd hookd is offline
2009 Ford F-150 SuperCrew
hookd is starting off with a positive reputation.
You have to have it but you will be allot safer, happier and have a smother ride if you had it. I don't know how the weather is were your at but I'm sure alberta has wind kinda like we do and there is nothing like having a swaying trailer jerking you around because you were to cheap to opt for the WD You can normally find them on craigslist for pretty reasonable. and for a brake controller just get the tekonsha prodigy is great and you can get a wiring harness that plugs in under the dash and saves allot of hassle.
__________________
HOOK
09 F150 SCREW 5.4 4x4 I finally got my dream truck
10 Dodge Caravan (I know its a minivan 4 kids don't fit in anything else that can get 25 mpg on the highway)
  #8 (permalink)
Old 09-11-2009, 06:33 AM
my 2010 has the wiring harness that plugs into the dash under where the jack is. . .unsure if I am the only one with that but it would be good to check before you buy one.
Also my 2010 has trailer sway control standard. I wonder if it would fight with the WDH. .
  #9 (permalink)
Old 09-11-2009, 06:54 PM
Z06PSI's Avatar
Z06PSI Z06PSI is offline
Z06PSI is starting off with a positive reputation.
I tow a dual axle car hauler for the Corvette and I am at 5700lbs and the WDH is a tremendous help with vehicle control.
__________________
Andrew, Christine, and Aidan Baker
2005 Navigator Ultimate
2002 Mil Yel ZO6 - 383 stroker 2.8L Kenne Bell and methanol.
  #10 (permalink)
Old 09-13-2009, 08:25 AM
I'm on my iPhone this weekend. Just hooking this weight trailer will show you the rear end sag and the steering will be scary-light. Refer to my last post.
Order a Tekonsha Prodigy or P3 from RVWholesalers. It's plug and play with HD Tow.
  #11 (permalink)
Old 09-13-2009, 11:22 AM
Mustang6147's Avatar
Mustang6147 Mustang6147 is offline
Mustang6147 is gaining momentum as a positive member of FTE.
My opinion is, you are at a threshold of needing, and not... When one hits a threshold, in anything, round up. You should get a weight distributing hitch. I am sure you already have a brake controller, as I dont think the camper place, that sold you your unit, would let you off the lot without one. Isnt that weight a 3500 lbs rule?
Anyways I would reccomend one (WDH) but will also reccomend trying to find one used... I have bought many, complete sets, head bars nap up brackets for around $150... Sure beats the new cost. I will also reccomend light bars. The torsion bars come is different weights, 500 to 750, or 750 to 1000 lbs weight ratings. Get the light ones, and make sure your ball height is set at trailer specs. 19 or 19 1/2 inches, ect... what ever it is.
In closing, you dont have to spend alot of cash, to acheive safety. I have an extra draw tight brake controller, U haul is also made by DrawTight, cost is around $100... SO everything should cost less then $250. And you are safe. Do you need this? maybe not... Do you want to be safe? maybe so... Keep the rig level... Axles have allignment, and a level rig will travel true, with little tire wear, and proper brakeing
__________________
06 SuperDuty 4x4 extcb 5.4, TorqShift, 4:10.
90 Mustang 9's, 750 HP Windsor. Ultratech Chassis
http://www.youtube.com/watch?v=pibt-TVgAx4
40 GMC truck, Mustang II, SBC.
Sig Sauer P229 Two tone.
  #12 (permalink)
Old 09-13-2009, 01:18 PM
Thanks again guys for your notes. I think I will invest the little cost to get this setup. On another note I decided to talk to one of the folks at the dealership who they referred to as the (expert). He mentioned that once again it wasn't required and actually said it could be harmful for this setup. He said that since this rig had a lower than normal TW that the WDH could actually cause the TW to be lower than the 10% requirement, and could cause the rear wheels to be too light on the road. I guess that might be true on a totally empty load so I'll just make sure to balance everything right.
  #13 (permalink)
Old 09-14-2009, 06:19 AM
Factory brochure weights try to make their trailers appear light so the dealer can sell you a trailer that's too heavy for you to tow. Trailers on the dealer's lot are at least 300 pounds more than their listed Dry Weight (doesn't include factory options like the awning, spare tire, etc) and tongue weights are usually understated at well.
The brochure tongue weight for my camper was 367 pounds.
The scale is accurate! This is before I filled with freshwater.
What trailer?
-- Chuck
Tags
2008, brake, controller, cost, distributing, distribution, expedition, f150, hitch, navigator, needed, sway, wd, weight, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
