Bent finger on pressure plate - Ford Truck Enthusiasts Forums
Old 09-09-2009, 05:00 PM
Skip1970's Avatar
Skip1970 Skip1970 is online now
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
i bought a used clutch for my bronco project it was out of a 6.9 diesel well when the guy pulled the engine he bent one of the fingers on the pressure plate, has anyone bent one of these back and run it? or should i just cut that one finger off? its a multi finger pressure plate not a 3 finger.. also some of the pressure plate bolts that hold it to the flywheel got messed up anyone know where to get replacements? they are special looking.
Ray
Old 09-09-2009, 06:25 PM
Skip1970's Avatar
here is a picture of the damaged finger
Old 09-09-2009, 11:48 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
I wouldn't put that in, even IF you could bend it back without breaking it off. Get your money back and buy a new clutch.
Old 09-10-2009, 11:03 AM
Skip1970's Avatar
Thats where you and me differ. this clutch was working fine before it was pulled.. im going to use it, now what do you think cut the finger off or bend it back?
Old 09-10-2009, 11:23 AM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
I wouldn't use it either.
But if you're going to do what you want anyway, then why bother asking for advice?
Old 09-10-2009, 11:46 AM
12ozd's Avatar
12ozd 12ozd is offline
12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold12ozd is a splendid one to behold
Quote:
It also wasn't damaged before it was pulled
I wouldn't cut it off,because they release the clutch.(could affect release)
I wouldn't bend it for fear of it breaking later.
Also,if you bend it back,remember the release bearing has to contact the fingers to release the clutch.Could cause bearing issues.
So out of those two options; I would get another clutch.
Good luck w/ your decision !
Old 09-10-2009, 12:51 PM
If you must, bend it back.
Worst case: you'll get some noise and a failing throwout bearing and you will be doing the job again. This is an oil burner, right? Not like it's going to spin 8000 rpm and cut the truck in half if it lets go.
Medium case: your clutch will chatter.
Best case: you can post back with "neener neener neener, my clutch is fine after 100,000 miles even though you said it wouldn't be."
Old 09-10-2009, 01:00 PM
Skip1970's Avatar
ya its for a offroad bronco im building, so its more of a toy, and i dont mind changing it out later or it making noise.
Old 09-11-2009, 02:21 PM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
I am notorious for fixing things that are best thrown out and replaced with new, but in this case, I think the risk of having to re do the hard work of dropping the tranny and or replacing a clutch and throwout bearing is more than the cost of a rebuilt pressure plate.
It has been a LONG time since I bought a rebuilt pressure plate but they were not very expensive to a my teenage mind way back when.
If you insist on "fixing" the fingers, be sure it is exactly the same level and profile as all the rest. The throwout bearing has to ride on those fingers and one that is significantly higher or lower will probably cause extra wear on the bearing or catch on something and yank itself out.
Some things just should be replaced when failure is labor intensive.
Old 09-11-2009, 03:05 PM
Skip1970's Avatar
i dont mind doing labor.. see the thing is if i cut it off it wont distort the pieces its attached to and wont cause the throwout to wear uneven.. but may disnenguage the clutch weird but im not sure.. then if i bend it might bent the other parts its attached to and cause weird clutch disenguagement.. maybe not though.. will be a interesting test for sure.. if i get a couple trips out of it i will be happy.
Old 09-11-2009, 03:25 PM
andym's Avatar
If you cut the finger off it will throwing the balance off and you will prematurely wear out the crank bearings.
Old 09-11-2009, 04:42 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Id take it to a clutch shop & replace the finger- probably cost $20
Old 09-11-2009, 05:07 PM
Skip1970's Avatar
Quote:
that is the most obserd thing i ever heard of! did they tell you that at autozone to sell you a new clutch? man hope u got some new muffler bearings too..
Old 09-11-2009, 05:45 PM
andym's Avatar
Ok smartass... take a look at the pressure plate and see where they welded balance weights to the outside of it. Now, use your head.... what do you think those are for? Keep using your head..... what do you think will happen if you remove a piece of metal from a balanced rotating assembly?
BTW, it's "absurd".
Old 09-11-2009, 06:42 PM
Skip1970's Avatar
BTW, it's "absurd".
U shouldnt assume, it makes a you know what out of YOU and ME! i was just going to remove enough material to CLEAR THE THROWOUT BEARING!!!! this little bit of finger being so close to the centerline of rotation would hardly effect the balance..
Ray
clutch adjustment issue joezzz 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 01-01-2017 11:13 AM
Pressure plate to fly wheel bolt holes brepei 1961 - 1966 F-100 & Larger F-Series Trucks 8 09-30-2015 12:35 PM
Clutch Mystery wfon 1961 - 1966 F-100 & Larger F-Series Trucks 32 09-04-2014 03:57 PM
Clutch fork return spring bigdan1979f-250 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-18-2012 06:28 PM
3 finger clutch ramtoo 1967 - 1972 F-100 & Larger F-Series Trucks 1 06-20-2005 07:44 PM
Tags
1975, bent, clutch, f250, finger, fingers, flywheel, ford, plate, pressure, replaced, stepped, truck, uneven, welded
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
