Bent finger on pressure plate - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 12-25-2009, 02:44 AM
tlk50's Avatar
tlk50 tlk50 is offline
tlk50 is gaining momentum as a positive member of FTE.
Ray,
Quit messin with these guy's and put that new clutch you bought in the Bronco. Your driven these people goofy! You got a nice run at it though!!!!
  #32
Old 12-25-2009, 05:14 AM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
Thumbs up
i only wish i had a new clutch for it, i knew i should have asked my wife for that for christmas!
  #33
Old 01-06-2010, 04:52 PM
Skip1970's Avatar
was walking thru the garage, kicked the pressure plate and was thinking about getting bolts.. anyone know if the screws are a special type for the pressure plate to flywheel, mine are all tore up heads rounded off and such.. well not all them..
  #34
Old 01-07-2010, 01:43 AM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Ford or other supplier. Or maybe just Wal-mart in the plastic pack...
ARP 150-2201 Pressure Plate Bolts
  #35
Old 01-07-2010, 09:42 AM
Skip1970's Avatar
well heck now that i know the size i can go get some at home depot,5/16-18, 1/2 in. Hex Head, mine look allot different though, like they have built in flastwashers and smaller hex heads.
  #36
Old 01-07-2010, 03:04 PM
The link I posted is generic, not researched as specific to your application. Look at the bolts. They have a shoulder on them. I doubt you can find bolts like that at HD. Even if they are grade 8s.
Best bet is Ford if you want to be certain.
The a-hole in me wants to suggest that since the bent pressure plate finger does not bother you, why would rounded bolts be a problem? Got Vice-grips?
  #37
Old 01-07-2010, 03:07 PM
Skip1970's Avatar
actually i could just weld a nut over the sripped out hex head.. or just weld the pressur eplate right to the flywheel! save a step all togeather!
  #38
Old 04-19-2011, 04:25 AM
Skip1970's Avatar
well thinking about putting it togeather, still havent decided to cut it off or bend it back..
  #39
Old 07-17-2012, 01:52 PM
Skip1970's Avatar
well still havent got it togeather! got a kick outa reading this thread again tho.
i musta been in a comical mood.
  #40
Old 10-16-2012, 08:25 PM
Skip1970's Avatar
got good news, a guy had a pressure plate he was gonna throw away with no bent fingers on it, im gonna use it! looks allot better then mine! and i got it free! woo hoo!!!!!`
will keep the other as a spare.
  #41
Old 06-19-2013, 10:53 PM
Skip1970's Avatar
Sill sitting on that free engine! Thinking of ways to get the water out of the cylinders i turned it upside doen and it came out the gp holes!!
clutch adjustment issue joezzz 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 01-01-2017 12:13 PM
Pressure plate to fly wheel bolt holes brepei 1961 - 1966 F-100 & Larger F-Series Trucks 8 09-30-2015 01:35 PM
Clutch Mystery wfon 1961 - 1966 F-100 & Larger F-Series Trucks 32 09-04-2014 04:57 PM
Clutch fork return spring bigdan1979f-250 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-18-2012 07:28 PM
Flywheel pressure plate issue 1ole4d Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 04-26-2009 08:30 PM
Tags
1975, bent, clutch, f250, finger, fingers, flywheel, ford, plate, pressure, replaced, stepped, truck, uneven, welded
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
