73-77 F250 4x4 Winter Project - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 12-25-2010, 06:25 PM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
hey not lookin to shabby, get her togeather so we can take it out and jump it!
  #32
Old 12-25-2010, 06:39 PM
AK FORD GUY's Avatar
AK FORD GUY AK FORD GUY is offline
AK FORD GUY is gaining momentum as a positive member of FTE.AK FORD GUY is gaining momentum as a positive member of FTE.
Highboy leaf springs and jumping is something I don't think I want to do anytime soon...... Sounds like a Kidney buster to me.
b-uno, be sure and give me a shout if you run into and hang-ups on that steering column. I can show you a couple tricks I did on mine.
  #33
Old 12-25-2010, 06:50 PM
Skip1970's Avatar
ya i wouldnt mind comming out and check your truck out in person if you get some time one evening, be fun anyhow.. daytime im stick at home with the kiddo
  #34
Old 12-25-2010, 07:11 PM
I'm sure we could work something out one evening. I usually spend my days when I'm home up working on the truck when I can and spend the evenings with my family. I'm sure we will get together at some point.
  #35
Old 01-08-2011, 03:47 PM
Pics of the converted steering column as requested.
Left Side:
Right Side:
Top:
I should have paid a little more attention to detail, but it'll work for now.
  #36
Old 01-08-2011, 03:58 PM
I got the carpet from Stock Interiors laid out in the floor board relaxing. I am not 100% happy with the results, but I think I can make it work. Stock interiors did not call me before the order was placed with the MFG as I requested. It is a little short side to side, but it's hard to tell by how much until I actually cut the carpet to fit under the firewall/steering column area. Once you cut it, you can not return it.
I think the color is a good match though.
  #37
Old 01-08-2011, 07:15 PM
BIGT94z's Avatar
BIGT94z BIGT94z is offline
BIGT94z is starting off with a positive reputation.
awesome progress! very nice winter build
  #38
Old 01-20-2011, 12:49 PM
Thanks BIGT94z.
Between a family friend passing away, home projects and just plain life, I got a few things done on the truck during my two weeks home. Now I'm back at work and can not wait to get back to the truck in two more weeks.
A little progress over the last couple weeks. My carpet showed up from Stock Interiors and as stated in many posts about ACC molded carpet for the 73-79 Ford trucks, it was not quite wide enough from door to door. I think I have that problem resolved, but I will not know for sure until I get back home on February 3rd. The color looks good though and I think I will be happy with the finished product. *** Just a heads-up for anyone ordering ACC carpet from any vendor. When you order it, specify that you want it to be shipped "un-trimmed". It will not have that real nice edge binding, but it will give you extra material to work with. ***
The carpet just laid in the cab.
33 Gallon Bronco tank installed.
Rear Spring Shackle Flip (Before)
Rear Spring Shackle Flip (After)
Shackle / Tank pic.
Rear shock mount relocation.
  #39
Old 01-20-2011, 05:34 PM
Raymond's Avatar
Raymond Raymond is online now
Raymond is starting off with a positive reputation.
Did you move the frame cross members to fit the 33 gallon Bronco tank?
  #40
Old 01-20-2011, 06:16 PM
Quote:
Yes, I moved the rear crossmember forward a bit. Fabbed the mounts for the top straps and modified the lower straps to work with the Bronco tank since it is a bit shorter front to rear.
  #41
Old 01-20-2011, 06:34 PM
Skip1970's Avatar
man that looks good! i need to get that dang tank outa my crew cabs CAB.... and into the frame rails.
  #42
Old 01-20-2011, 08:18 PM
wyckedcombo17's Avatar
wyckedcombo17 wyckedcombo17 is offline
wyckedcombo17 is gaining momentum as a positive member of FTE.
Looks good! It's comin along nicely!
Quote:
When you say you moved the crossmember, did you NEED to? I'm interested in putting a bronco tank in my truck and I don't really have the time to fab the cross members
  #43
Old 01-20-2011, 08:54 PM
I'm sure it could be done without moving the crossmember, but I did not even try. There will be some fabbing or creative engineering involved either way. Remember you are trying to suspend, support and hold 33 gallons of fuel in place. I am still kicking the idea of reinforcing the lower straps some how and I plan to build a skid-plate to protect tha tank also.
If you are getting a used bronco tank, try and get the skid-plate also. the lower tank mount and the skid-plate are one piece
  #44
Old 01-20-2011, 09:24 PM
Redneckryder's Avatar
Redneckryder Redneckryder is offline
Redneckryder is starting off with a positive reputation.
hey---AK. you should be close enough to snag parts off that highboy the Top Gear guys left up there! lol
  #45
Old 01-30-2011, 08:02 PM
So if I was going for the extra capacity in the tank with minimal welding/custom fabbing involved should I go with the 38 gallon from LMC truck? Are you runing into any clearance problems for exhaust or anything? I can understand why the skid plate is necessary fosho
65 F100 4x4 drive train upgrades Amphihauler 1961 - 1966 F-100 & Larger F-Series Trucks 14 10-15-2016 06:10 PM
frame swap from a 77 f250 l4x4 ong box to my 66 f250 2wd long box mharring 1961 - 1966 F-100 & Larger F-Series Trucks 4 09-05-2011 11:07 PM
Whats stronger mated or divorced np205? SilverHighboy Clutch, Transmission, Differential, Axle & Transfer Case 11 07-12-2010 11:39 AM
1977 F250 Transfer Case Heimer77 Clutch, Transmission, Differential, Axle & Transfer Case 7 02-06-2007 08:41 AM
77 F250 4x4 frame to 78 F250 4x4 frame question apachetech 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-26-2006 04:32 PM
Tags
4x4, 73, 7377, 77, 78, box, f100, f250, frame, manual, parts, power, putting, steering, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
