Fuel pressure regulator location & replace - Ford Truck Enthusiasts Forums
Old 09-09-2009, 03:07 PM
matpasch matpasch is offline
matpasch is starting off with a positive reputation.
My 1993 f250 with a 351, 5spd ext cab 4x4 is still getting bad milage(around10 mpg) after full tune up, besides fuel filter haven't replaced yet, so I wanted to test and or just replace my fuel pressure regulator.
Where abouts is it located and any tricks to removing it, besides, I guess, de-pressurizing the fuel system by tripping the inertia switch and letting motor run till empty???
Thanks mat
Old 09-09-2009, 03:22 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
FPR is located at the back of the motor on the drivers side on top of the fuel rail. Unfortunately it is attached with 3 allen head bolts from underneath which are difficult to access on an assembled motor... to put it mildly. In ths pic the FPR is to the right near the firewall just above the coil with a red vacuum line going to it. You can also see a gauge just above the oil fill, that gauge is attached to the shrader valve on the fuel rail.
Old 09-10-2009, 10:28 AM
dan1101's Avatar
dan1101 dan1101 is offline
dan1101 is starting off with a positive reputation.
Would the fuel pressure regulator make any noise while doing its job?
I have a 95 F-150 5.0 that will crank but not start. I can hear the fuel pump run when I turn the key to Acc. The past few days I drove it, I cranked it 5 or 6 times and it started, then I was able to drive it the rest of the day without trouble. It always seems to be the first start of the day.
Today I had the problem again, checked the inertia cutoff switch, popped the hood to check the 20A fuse for the fuel pump, both seemed fine. After trying to crank the truck again I left the ignition on, then went back to the engine to look around. I heard a little whirring sound from the driver's side of the engine compartment. So I turned the key and it started right up. Coincidence? What might the whirring sound have been?
Old 09-10-2009, 10:33 AM
Conanski's Avatar
There are several solenoids in the engine bay that make various noises when energized but the FPR doesnt make any noise. You may have dirty fuel injectors that are leaking and making it difficult for the pump to build pressure at startup. You can confirm this by attaching a gauge to see if the rail holds pressure and if it doesn't run some cleaner through the fuel system, have the injectors professionally cleaned, or replace them.
Old 09-10-2009, 10:44 AM
dan1101's Avatar
I ordered a pressure gauge today, figured that would be a good place to start along with a fuel filter for good measure.
Old 09-10-2009, 12:14 PM
dan1101's Avatar
Another thought...the noise I heard in the engine bay could have been the fuel pump running at the back of the truck. Which brings me back to the regulator. Does it allow the fuel pump to run directly or indirectly, and could that be happening while the ignition is on but truck isn't running?
Old 09-10-2009, 12:33 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
The only thing the fuel pressure regulator does is increase the rail pressure when it sees less vacuum.
Old 09-10-2009, 12:43 PM
Conanski's Avatar
Adding to what Andy said... the FPR is not controlled by the computer or any other device it's just a dumb vacuum sensitive valve. If however your fuel pumps are running constantly when the key is on but engine off then you have another problem, either a stuck pump relay or bad EEC.
Old 09-10-2009, 01:00 PM
dan1101's Avatar
The fuel pump isn't running constantly, I hear it running when I turn the key and it stops in a second or so. Then while under the hood with the ignition on I heard a quiet whirring sound, I then tried to start the truck again and it started right up.
Old 09-10-2009, 01:11 PM
andym's Avatar
I don't know what the whirring noise was, but it didn't have anything to do with the fuel system.
Old 06-30-2010, 02:07 PM
Matthew Martin Matthew Martin is offline
Matthew Martin is starting off with a positive reputation.
misfiring
My 96 f-150 is misfiring. I have replaced the fuel pump and four of the fuel injectors. So my question is is if the fuel pressure regulator make the truck misfire while I am driving?
Old 06-30-2010, 03:39 PM
Conanski's Avatar
A misfire is usually electrical. Pull the codes first and if that comes up all clear test and/or replace the high voltage ignition components.. aka.. plugs, wires, and coil.
Old 12-07-2012, 10:31 AM
keoghzayd keoghzayd is offline
keoghzayd is starting off with a positive reputation.
Ford f150
Quote:
Hey i wasn't sure how to reach you directly so ill ask it on here, have you figured out your problem? my truck is doing the exact same thing, please email me if possible its ryanhilgeman@yahoo.com, it usually does it after sitting for periods of time and it can take anywhere from 5min to and hour before i hear that second sound engage i assumed it was pump also. I have dual tanks tho and it doesn't matter what tank i have it on it will not start until i hear that pump engage for the second time, ive replaced fuel relay, fuel filter. So any help would be greatly appreciated its driving me insane, took it to mechanic and of course it wouldn't do it for him, my pressure was to spec as well.
2003 Expedition 5.4L Fuel Pressure Regulator CapitanRon 1997-2006 Expedition & Navigator 20 01-14-2015 05:20 PM
99SD Fuel Pressure Regulator Location??? caliaviation Modular V10 (6.8l) 4 05-28-2014 09:50 PM
FUEL PRESSURE REGULATOR VONxRUBENxLA Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 07-24-2011 01:15 PM
locate fuel pressure regulator jgaspard 6.0L Power Stroke Diesel 11 11-21-2010 06:46 PM
2000 f150 5.4 fuel pressure regulator location fordboy_52 1997 - 2003 F150 0 10-21-2009 07:49 PM
Tags
1987, 1988, 1999, bad, change, f150, ford, fuel, location, make, pressure, pump, regulator, replacing, sound, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
