20" tires for 06
I personally feel that the 305's are a little too much tire for a stock 20x8.5" wheel. The added sidewall deflection is going to make things more unstable at highway speeds, which is probably the last thing you want in a truck with such a high center of gravity. Unless you're planning to going with a 9" or 10" wheel to accompany them, I'd consider something closer to the stock 275mm width.
You can get the Terra Grapplers in a 275/60/20, which will give you about 33" of height and fill in the wheel wells a little for a more 4X4 like look and they're about $40 cheaper per tire.
Another nice option would be the Bridgestone Dueler A/T Revo's. I've had them on a previous truck and they're an excellent tire. Great all around traction, even wear, quiet on the highway, aggressive looking tread pattern and reasonably priced (about $80-$100 less per tire in comparison to the Nitto).
Your choice really....but whatever you decide, I'd reconsider the tire size on the stock wheels.
How many miles have you got on them at this point and how are they wearing?
I have 10k miles on my tires and so far so good.
kameronth
12-17-2009 08:10 AM
