shifting issue on 95 f150 5 spd
Old 09-08-2009, 10:05 PM
caribcanuk's Avatar
caribcanuk
caribcanuk is offline
i just bought a 95 4x4 the truck has the 300 with a 5 spd overdrive. its real tough to find the 1st and 2nd gear the gears work fine when you find them its just tough hitting the right slot . im thinking something wore on the shifter but only has 204.000 km any ideas
Old 09-09-2009, 09:12 AM
jas88's Avatar
jas88
jas88 is offline
The most common problem on your trans is the shifter pins break off which causes the problem you describe. Go on eBay and type in "M5R2" and you should find a kit that replaces the pins and the cover for about $25 or so.
Old 09-09-2009, 07:10 PM
caribcanuk's Avatar
caribcanuk
awesome i just ordered the kits was like 32 us hopefully that cures the problem
Old 09-09-2009, 07:48 PM
BigBlue88's Avatar
BigBlue88
BigBlue88 is offline
The shift forks also bend on those transmissions. I recall those transmissions often get reliable around 100kmi, so at 204km (~127kmi), you're pushing your luck. Do like Jas88 says, maybe replace the shift forks, and definately replace the 3 rubber seals on the back of the top plate. Search the 87-96 forum, there's lots of threads on the M5ODR2 (HD) transmissions.
Old 11-04-2016, 04:08 PM
John Patton's Avatar
John Patton
John Patton is offline
I have an 89 f150 where I can't get it into 1st or any gear anymore, do you think it's the same problem ?
Old 11-04-2016, 09:58 PM
The Frenchtown Flyer's Avatar
The Frenchtown Flyer is offline
It could be insufficient clutch hydraulic slave cylinder travel, due either to it needing bleeding, or too much firewall flexing, as was the problem with my '85 van.
Old 11-04-2016, 10:24 PM
John Patton
oh I will have to check em when I can
Old 11-04-2016, 10:25 PM
John Patton
how would I check the firewall flexing though ?
Old 11-05-2016, 11:30 AM
In my case the firewall was never welded to the toe board. The seam was just covered over with a bead of sealer. After many attempts to bleed the system I knew something else had to be going on. I had a friend stroke the clutch pedal and i noticed the movement on the firewall. But, I was also an automotive engineer at the Blue Oval and observed lab tests in the Chassis Test Lab where severe clutch pedal loads were applied to the firewalls and the firewalls moved visibly and through dial indicator movement. Some additional reinforcement may be in order. Just sayun'.
Old 11-06-2016, 07:05 AM
John Patton
ya all seems to be in good order, do you think if my shifter was loose, I would have a problem, or could it be my shift forks ?
Old 11-06-2016, 10:19 PM
It could be either - or both.
I had a foreign car - a Hilman - that I could not get in reverse gear. It was a sheared pin in the shift lever.
Old 11-06-2016, 11:10 PM
John Patton
so the safest bet would be to just swap both out then, anyway I could get them cheap online ?
BrianF-250
Fifth Wheel & Gooseneck RV Towing
12-02-2017 10:56 AM
C600
Large Truck
11-15-2017 08:47 PM
fordka
05-10-2017 12:45 PM
SpeedThrills
11-29-2016 10:30 AM
mattri
16
09-02-2016 09:26 AM
Quick Reply: shifting issue on 95 f150 5 spd
