F-350 with a new life purpose...rock crawling!
hey guys though i would share a bit with you guys from my weekend.
i went to Moab, UT for the weekend with my buddys that go there every year. this was my first trip there.
we decided to to the triple threat as its known.. has obsticals like the launch pad and the golden crack... however we didnt make it to far past the Lauch pad before my buddys jeep busted a lower control arm... so that was the end of the day... back to the begining.. anyhow i got a bunch of pictures and some video that im going to be posting up at a later date... now onto the new direction...
i am looking at doing a coil over conversoin in the front and a full spring lift in the back(instead of the blocks i have now)... lock rite locker in the front, selectable locker in the rear. winches front and back off-road bumpers w/ winch mont... those are just bolt ons, im also looking at choping the bed of the truck up, im going to make the shackle mount about where the end of the truck is to avoid the bumper hung up... looking at chopping 6-8 inches off the back end! its going to be a LONG pretty expensive road but i have a new found purpose for the truck...
any idea's that you might have for mods that i have mentioned or something that would be at least trying will be awesome and very much appreciated!
just though i would share and like i said ill have a new album posted later on once i get with everyone that went to get there photo's... thanks for reading and sorry about the sorta off topic post!
He has a point... don't you use your truck as a daily driver also?
i always wanted to convert my truck over to a 6x6 with some rockwells. You will have to go with a ARB in the rear axle because the 10.25. I hate ARB's but will be putting on in my jeep that has a 10.25, but they leak and you loose your locker. If your really thinking about doing heavy wheeling i would ditch the axles you have and go with rockwells. You can build up some decent dana 60 but its expensive!! knuckles are 500 bucks axles shafts are 1800 for the long fields. Sense you plan on changing your front suspension anyways it would be worth the extra effort to put rockwells in and probably cheaper. Love to see what you build though not many superduties on the trail.
Couple things, selectable locker goes in the front. Without it, try steering. When your front axle is locked you dont steer. So if you ever wanted to drive while using 4wd, you would want a selectable, or limited slip in the front. If you like to turn that is. I have a detroit in the rear of mine, and love it, but I am used to the driveline noises it makes. Takes some getting used to. Absouletely do not go that far, on a daily driver. As there will come a time, were you dont get done as much as you wanted to, and the truck doesnt move, or you took it this far apart, part store isnt open or doesnt have what you need to put it back together ona sunday. Ask me how I know any of the above, as I went through all that. Now I have a back up DD for my DD and this, which I am still working on (5 years of setting it up just how I have wanted it)
Full Traction makes a coil conversion for our trucks, that I myself will be getting when I get outa the sand box. Kinda pricey but puts a brand new coil system on the front. Not sure if it would be good for rockin but trying to throw some ideas out there for ya.
EDIT Heres the link for ya http://www.full-traction.com/detail....TID=394&NOTES=
