Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 09-08-2009, 09:11 PM
F350-6's Avatar
F350-6 F350-6 is online now
Slow Typing
F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation. F350-6 has a spectacular reputation.
Quote:
Originally Posted by Ziggy. View Post
Nothing special, its a stock, but very healthy HPOP, 238cc hybrids, and custom tuning, idling at 750 rpm
That's the part that had me curious. The custom tuning with those sticks probably wasn't customized to minimize smoke at start up, if you know what I mean. That Jody fellow seems to be more concentrated on the go fast part of the equation.
If it clears up when warm, you could either start it up in the stock setting, or just ignore it. With the hybrids, I'm not sure it the stock setting will cure the issue. The high idle for a faster warm up may be the way to go.
The other option of course would be to move South. We had a high of 98 here today. No issues with cold starts here.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 320,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #17 (permalink)
Old 09-08-2009, 09:17 PM
robs01f250's Avatar
robs01f250 robs01f250 is offline
robs01f250 is starting off with a positive reputation.
eddie how does friday sound? We could meet up around 5 when i get off work. let me know if this is alright
__________________
2001 F250 7.3 6speed 4x4
6637, foil delete, painted IC pipes
Isspro boost, pyro, DP f5 gauge
DP Tuner 80e, 120r, and 140 SMOKE
BF Goodrich AT 295/75/16, MKO 5'' straight piped
Bull Bar and camo seat covers, TRAIN HORNS
  #18 (permalink)
Old 09-08-2009, 09:31 PM
Ziggy.'s Avatar
Ziggy. Ziggy. is offline
Ziggy. has a good reputation on FTE. Ziggy. has a good reputation on FTE. Ziggy. has a good reputation on FTE.
Jody? lol, i've met the man, but havent run his products. Matt Robinson does mine. My truck starts fine, 95*, -5*, always like a champ, not coughing, sputtering.
Stock setting? lol I dont have one, the closest thing i've got is my heavy tow tune. It doesnt really matter too much either way, with the injectors and his tuning whether its hot or cold I always have a healthy haze rolling out for quite a few min after start up.
__________________
Cory--E.T.A.P.S. Co-founder
2002 F-250 SCSB 4x4 6spd, 4'' and 35'' Nittos, forged rods, 238/80, h2e, Tuned by Matt, 6637, lots of Nitrous, CPR+ RR,140v IDM, 6'' black stack, South Bend DD 3600, Water Inj, DiProcol gauges, Excursion aux fuel tank, ATI dampner, Comp 910s, SmithBro pushrods, 08 Seats, No intercooler, CCV, Hutch & Harpoon, 3 batteries, Nothing is stock anymore lol
Quote:
Originally Posted by jdecker88 View Post
Can't is not in Cory's vocabulary he's like Chuck Norris with a wrench
  #19 (permalink)
Old 09-08-2009, 09:50 PM
Bigcat350's Avatar
Bigcat350 Bigcat350 is offline
Caution! Will Blow Smoke.
Bigcat350 has a good reputation on FTE. Bigcat350 has a good reputation on FTE.
Quote:
Rob that works good for me. Give me a call when you can
__________________
Eddie Late 01/99 F-350 XLT 7.3 EC DRW 4x4 6-speed 4:10, some common mods done. 6637 filter & Pete's Cover, Billet Grill,Muffler Delete,Stancore GPR,2 Pillar Pod Gauges,Swamps Hybrid Single Shot Injectors,DP Tuner NS,Modified Stock,Hi-Idle,80E,120R,140A,Foil Delete,CCV,AIH Delete,Garrett GTP38R BB Turbo with a 1.15 Housing, Valair Clutch. And more. Over 400HP BIG RED TRUCK - PAA#79
  #20 (permalink)
Old 09-08-2009, 10:11 PM
Bigcat350's Avatar
Stock don't help. I don't plan to give up that easy. Cant move ether so I will look on. Maybe some tuning would help? Any way thanks for the ideals
__________________
  #21 (permalink)
Old 09-08-2009, 10:24 PM
SuperDoodie's Avatar
SuperDoodie SuperDoodie is offline
2002 Ford F-350
SuperDoodie has a good reputation on FTE. SuperDoodie has a good reputation on FTE. SuperDoodie has a good reputation on FTE.
Eddie, one thing I would like to add is that I have had 3 different motors in my truck but all had single shot injectors and big oil systems.. All three had the same characteristics as you are describing with the smoke on cold start and the shakes..
I personally don't worry about it anymore, it seems to be a common thing with highly modded truck.. I should also note that I dropped my compression a turd hair on the current motor.
__________________
Greg .. Dyno'ed 563 HP on 02/06/2010
2002 Ford F350 4wd, Built motor, custom cam, comp 910's, DI pushrods, H-11 headstuds, Casserly hybrids injectors, Garrett GT42 turbo, Terminator dual HPOP's , BTS Transmission, Tru Trac rear, ITP regulated return w/fuel bowl delete, Walbro fuel pump, Airdog fuel separator, coated exhuast manifolds, Diesel Power Products Intercooler, ATI Damper, Melling LPOP.
  #22 (permalink)
Old 09-08-2009, 10:41 PM
Bigcat350's Avatar
Greg your not the first to say this but you are highly modded I still have drop in stuff. I guess I will try a few things before I give up. At least it runs like a bat out of he_l and it does start good. I need to get my chip upgraded to my new set up any way but I want to put it on the AE and see where its all at.
__________________
  #23 (permalink)
Old 09-08-2009, 11:04 PM
mueckster's Avatar
mueckster mueckster is online now
Redneck Wrencher
mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold mueckster is a splendid one to behold
I don't get any smoke when I start mine. except a puff of black smoke. It idles best usually on cold start up (~75-80* here). I get a flutter and shake intermittently, after warm up, at idle. It runs smoother when under a slight load like when in gear and a/c is on. I removed my HPX (had slight seep ffrom O-ring on HPO rail fitting) when I installed the Stealth Pump and plan on putting it back after my O-rings (from Rick's) and 1.15 turbine housing (from Clay) arrive. I will wait until all the parts are here, so I can R&R the 38R while the the HPX is out of the way.
__________________
-Roland-
'01 F-250 Lariat CC SB 4x4, DP Tuner F6, AFE II w/ Pete's Cover, Garrett GTP38R w/ 1.15, 6.0 IC, Casserly SS 160cc 100% over, Stealth HPOP, Autometer Phantom gauges, DIY HD 4R100, 4" MBRP, Procomp lift pump, CCK, TruCool, billet 710 cap, Truetrac rear
PAA Member #62
Tags
01 , 175146 , 350 , dyno , f350 , icp , idle , ipr , located , matt , powerstroke , replace , robinson , skip , swamps , van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
