7.3 trans? Slipping in reverse - Ford Truck Enthusiasts Forums
Old 09-08-2009, 12:08 PM
sharps-Nut sharps-Nut is offline
sharps-Nut is starting off with a positive reputation.
Hello all. I own a 2003 7.3 with auto trans 37k on the truck is as ford delivered it bone stock. This summer I had a transmission shift improvement kit installed trying to correct a less than crisp shift that has existed since new. The truck went on a family vacation to colorado and performed well with only one noticed glich. While using the engine as a brake, locked in 1st if you were going to slow and used throttle then the brakes the lock up torque converter would really lock up and unlock hard. Well this weekend while trying to back my camper in to its spot at the lake another glich appeared, it would not push the camper uphill, it slipped with no movement, 2500 rpm worth of rev, no tire slip. I used 4 low to get the camper set and it pulls fin in forwward gear but reverse pushing a load is all but gone. What went wrong and where do I go from here. Sorry for the long post but I wanted to cover the entire story. So do I trade it off while it still moves, fix it, will this problem come back again, and why did it break to begin with. My trailer only weighs 7k and its been well cared for. I'm lost and really pissed about this as I planned on keeping the truck as a puller for 10 years then maybe a daily driver beyond that. Help?
Old 09-08-2009, 01:54 PM
cleatus12r cleatus12r is offline
cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.cleatus12r has a spectacular reputation.
Quote:
I'm trying to figure out whether or not you actually have a problem. Basically, you are experiencing what some small circles of people call "too high of a gear ratio in reverse". There is not enough torque multiplication through the reverse gear ratio and torque converter to get any power to the ground. I really feel that there's nothing wrong with the truck.....it's just that you don't have either enough gear or enough power. You found out that low range is a godsend with the 4R100 transmission and most folks will recommend that you use that whenever you plan on backing a heavy load.
Old 09-08-2009, 02:36 PM
Maybe?
I have backed my camper or loaded trailer before and not had the problem you describe. The trip before this I noted it shuddering if you back up using a fair amount of fuel, like a hurried three point turn around. I would be well pleased if its fine but it sure never acted this way before. What if anything would you do at this point. I showed a mechanic friend at the lake by power braking it in reverse it spun up to 2500 with no real desire to slip a tire but would pull instantly in foreward. Does 1st and reverse share the same clutch pack. Is reverse a higher han 1st. I would not argue with anyone as I don't know. I do know I cant afford to travel with it and have a roadside break down, but that said dont have 5k to fork over for a bts trans.
Old 09-08-2009, 02:50 PM
Oh.
The infamous torque converter semi-lockup in reverse caused by low transmission pressure either from an internal leak, worn pump, or aerated fluid.
Easy: Loose transmission filter allowing air intrusion around seal in pump.
Not as easy: Pump replacement or sealing ring replacement.
Hardest to swallow: Transmission
First is 2.71:1
Second is 1.54:1
Reverse is 2.18:1 (ridiculously high)
As for apply/holding components:
First gear in "D" range
Forward clutch applied
OD one way clutch holding
Low/Reverse one way clutch holding
Reverse gear
Coast clutch applied
Direct clutch applied
Low/Reverse clutch applied
If you have engine braking in 3rd gear, the coast clutch is working
If you have no issues in 3rd or 4th, the direct clutch is working
The Low/Reverse one way clutch has to work if you have 1st gear as does the OD one way clutch.
Old 09-08-2009, 04:03 PM
Wow
Wow cletus you seem to really know your transmissions. Your last post got me to thinking and reading. I looked up the stall specs on my tranny and will start with that and your information on engine braking. With any luck that will catch it if not I guess we go deeper. The leaking at the filter would seem possible since it would have been out at shiftkit install. Thanks for the heads up and the info. SN
Old 03-02-2014, 02:36 PM
dirtrider250 dirtrider250 is offline
dirtrider250 is starting off with a positive reputation.
What ended up being the fix for your reverse slipping?
Old 03-02-2014, 03:18 PM
JOHN2001's Avatar
JOHN2001 JOHN2001 is offline
JOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to beholdJOHN2001 is a splendid one to behold
With only 66 post and this being back in 2009 I doubt you're gonna get a response from this guy.....
Old 03-03-2014, 09:01 AM
Slipping
Surprise a 66 post lurker will respond. I had recently had the trans serviced a and a shift improvement kit installed. I returned the truck to the shop and he dropped the valved body. It had blown the valved body gasket. The installer apologized and fixed the issue at no cost despite having done the work 3 months prior.
That firmed up my shifts and eliminated the slipping in reverse and I have been very happy with the truck. Purchased may of 03 with 49 miles on it. It has been garage kept and only used for pulling our 30 ft rv and heavier farm pulling duties. It now has 62k on the clock most all pulling and has only been pulled with the od on once. That trip made the od light go blinky bliny in limp mode. That was at 30k I since stuck with the idea the od is the weak link and have always pulled at 2500 rpm od off. The truck has remained trouble free. I planned on trading it off at 10 years but given the cost of new one's and as dependable as it seems that date has been pushed back to an unknown date. Last summer's vacation racked up 5500 miles of hard mountain pulling and it happily chummed along like it did in 03. Color me a very happy 7.3 psd owner. Sorry for the long reply SN
Old 03-03-2014, 09:11 AM
JOHN2001's Avatar
I stand corrected... Thanks for getting an answer for the guy asking you 67 post lurker
Old 03-03-2014, 12:24 PM
It's a good forum with a good group of folks willing share their knowledge. I just have been lucky enough to be able lurk and learn. Hope he can get his issues fixed w/o spending 5k on a high quality trans rebuild. The lurker, aka SN
Factory camera problem Chauncey 1999 to 2016 Super Duty 15 02-26-2017 09:08 AM
Looking for Mark (retired ford trans engineer) DieselDenny 1999 - 2003 7.3L Power Stroke Diesel 12 12-22-2016 06:51 AM
The Building Of My 97' OBS. Kingkong0192 1994.5 - 1997 7.3L Power Stroke Diesel 79 04-15-2016 01:38 PM
4R100 Upshift Engagement causes Engine Braking Decipha Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 13 03-03-2015 09:47 AM
03 7.3 leaking trans fluid from inspection plate Bluebronco85 1999 - 2003 7.3L Power Stroke Diesel 10 06-12-2014 10:43 PM
Tags
2003, 4r100, 73, 99, backing, clutch, do, ford, gear, issue, join, lakewhat, repairing, reverse, slipping, stall, trans, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
