Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1949 f6 carrier bearing
Old 09-08-2009, 09:39 AM
rat49f6's Avatar
rat49f6
rat49f6 is offline
Ok guys so i need to replace the drive shaft carrier bearing on my 1949 f6... id really like to upgrade to a one peice unit if possible. I think the original parts are avalible nos still if thats not possible... i will pst in the 48 - 60 also incase someone there can help
Old 09-08-2009, 10:02 AM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
I haven't got a good look at an F6 carrier bearing yet, but my '74 F100 had one. That said, a later style may work. That may be something your local driveline shop can tell ya about.
Old 09-08-2009, 10:35 AM
rat49f6's Avatar
rat49f6
rat49f6 is offline
Was it pressed on? Do u think one with set screws would work?
Old 09-09-2009, 05:19 PM
havi's Avatar
havi
havi is offline
I don't remember, it was a long time ago. I assume this truck you have was a 158" wheelbase? I just looked at a short version F6, and it didn't have a carrier bearing on it.
Old 09-09-2009, 05:41 PM
rat49f6's Avatar
rat49f6
rat49f6 is offline
i think end to end it measured something like 19'
so that would make sense
Old 09-16-2009, 09:22 PM
havi's Avatar
havi
havi is offline
I apologize, I did find a carrier bearing on my F6. I just didn't look forward enough. Now that I got it home, I was able to crawl underneath.
One option is going without the carrier bearing and run a bigger driveshaft like that of a late 70's Ford 4x4. You can get conversion u-joints at the local part store.
Old 09-17-2009, 06:28 AM
rat49f6's Avatar
rat49f6
rat49f6 is offline
Thanks for the cotinued assistance...
I cant go single shaft because of the mods i have done to the truck
Old 06-14-2013, 02:07 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C3AZ-7025-B (replaced 8A-7025) .. Driveshaft Center Support (carrier) Bearing / Stamped with BIN: X3204G or 15039 or 550010 or 550301 or 207L or 207LO
BIN: Bearing Industry Number, what autoparts stores/bearing shops go by.
Applications: 1948/52 F2/F3/F4/F5/F6 / 1953/56 F250/350.
Available from any autoparts store as it was also used as an output shaft bearing for Ford 3 speed manuals from 1949 thru 1987!
frenchyo
04-29-2015 12:11 PM
Steven Gatley Sr
18
12-27-2014 08:16 AM
John & Old Ford
20
12-18-2013 12:37 PM
newbie2006
10-28-2013 03:53 PM
oscardgarza
04-02-2013 07:30 AM
Quick Reply: 1949 f6 carrier bearing
