ok i checked all the fuses under the dash they are all good (I don't have the fuse cover some I'm not sure of the exact fuse). I guess I'll have to find a schematic and trace the circuit. Does that circuit go through the range switch on the trans (over the shift shaft)?
could also be the switch on the trans or in the column-try putting it in reverse and wiggle the shifter -mine is like that it won't work till I wiggle the shifter towards park and neutral never fixed mine I just deal with it
