emissions info
emissions info
I bought a 75 F-100 in Flagstaff AZ in January 09, There are no emissions there. Now I will be bringing the truck to Phoenix and wondered if someone would now what if anything I will need to pass emissions here. The truck is 4 wheel drive with a 360 and a 4 barrel edelbrock 3 speed auto. There is no smog pump on it now and I think it just has two glass packs no CAT, VIN # F11YRV25040 Also all the decals under the hood for emission info are gone "does anyone know were to get these" thanks in advance for any help.
If Phoenix is anything like what the CA emissions requirements are, ALL the emissions related parts have to be re-installed and be in good working order.
This includes the catalytic converter, EGR valve and related parts, the smog pump and all its related parts, PCV and related parts.
In CA, if any of these parts are missing or not in working order, the vehicle cannot be registered.
If the parts are obsolete (most are) there is no waiver like there once was. It's fix it...or park it.
The emissions decals are obsolete, no longer available from Ford. I dunno if any have been reproduced...or not.
Do you know what state the truck was sold new in?
Look on the metal Warranty Plate, which is located on the face of the left door below the latch for the DSO code, post what it is.
1975 F100 sold new in CA (DSO codes 71 or 72): Thermactor Emission (smog pump) / EGR Valve / Catalytic Converter / PCV System / Evaporative Emission System.
In Phoenix, 1975 and up vehicles go through a visual inspection for emissions equipment. You will need the factory emissions equipment installed and operating correctly in order to pass emissions visual. 1974 and older have no visual inspection and only need to pass a exhaust sniffer test.
You can learn more here (AZ environmental quality site)...http://www.azdeq.gov/environ/air/vei/index.html
or
http://www.myazcar.com
One option to avoid emissions is to register the vehicle as a collectable vehicle (25 years or older). This would change your insurance and limit the mileage you put on the truck each year. http://www.azdeq.gov/environ/air/vei/motor.html
There's other ways to get around inspections too. One way is if you have someone who lives in a city other than Phoenix or Tucson and you state that the truck is used at that residence (like a truck used at Lake Havasu for towing a boat).
or
Sounds like you're going to have a tough time bringing it down to PHX according to Rey...why not just leave it registered in Flagstaff?
Ebay and classifieds can fetch you parts, but...their functional state is questionable.
I've looked up emissions parts. You don't want to know the last list price for some stupid vacuum amplifier or such. As nearly everything has been obsolete since Carter was in the office, they are free to play the pirate.
phoenix is fine with it having the edelbrock carb, they dont check for EGR's and a aftermarket intake and headers is ok also.. i had no problems with my 77 dodge in phoenix, it had edelbrock carb cam and intake and hooker headers.. passed easily.
U shouldnt have a problem, dont change anyhting tell you take it down and have them tests it.
Ray
Ray
Ray
Ray
I would make sure it's tuned well before you take it through emissions (without spending $ on adding anything, just basic tune-up stuff). I've failed emissions on my 1974 before, running too rich. Just needed the carb tuned up.
f18cowboy
26
04-15-2023 04:40 PM
Powersmokin137
15
08-25-2016 07:32 AM
loblazer
16
09-11-2012 06:57 PM
