Autoline carb?? - Ford Truck Enthusiasts Forums
Autoline carb??
Old 09-07-2009, 10:45 AM
highoctane74's Avatar
highoctane74 highoctane74 is offline
highoctane74 has a great reputation on FTE.highoctane74 has a great reputation on FTE.highoctane74 has a great reputation on FTE.highoctane74 has a great reputation on FTE.
Autoline carb??
My 429 came with an Autoline C857A Carb. What CFM would it be....can`t find anything on the Internet......Is it any good.......Thanks
Old 09-07-2009, 11:36 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Autolite
Is that the only numbers on the carb?
Old 09-07-2009, 11:58 AM
That is the tag on the top....only number I could find.....a search found one for sale on ebay but no info.....I will look again tomorrow....
Old 09-07-2009, 06:14 PM
benshere benshere is offline
benshere is starting off with a positive reputation.
autolite carbs
I am going by memory but it will be close. It may be one of the 4300 series of carbs. The larger was 4300D and the slightly smaller was 4300C or visa versa. I think the throttle bores are the same, but the venturi's are slighter bigger for the larger cfm one. I have a 70 mach I that has a smaller version and I believe the 429 was a larger version. Smaller one was ~600 cfm, and larger was ~650-700 cfm. Also, beware!! Some of the 70 429 CJ motors came with a cast iron intake and a Quadrajet (as in Rochester). I had a 70 429 CJ with one. Almost swatted a smart A** parts counter man over that carb once. I told him that I wanted a rebuild kit for a Quadrajet on a 70 429 and he got really insulted (typical chevy man). He told me that Quadrajets were GM carbs and Autolite was for fords. I said O.K. give me a rebuild kit for a 70 cutlass with a Quadrajet----problem solved. In reality that Quadrajet had an "Autolite" tag on it.
I also think that some hollys came on them, but may have a "Autolite" tag as well. Google Autolite 4300 and see what you get----I will soon as I "submit" this post.
Old 09-07-2009, 06:30 PM
After a really quick search (http://mustangtek.com/4300/4300.html) , the closest thing to your number is C8SF-G or C8SF-H which are for 68 429's. Any C8** with an A designator seem to be for smaller engines. You may have been slightly off with the C857A number---check a little closer.
I was wrong in my previous post, the larger 4300 had a 1.25" bore while the smaller one had 1.00" bores.
I did a Google on Autolite 4300 and saw several sites, just go to all of them. LOL
Carb Question Ramlo Large Truck 1 10-19-2016 06:59 PM
Rebuilt Carb Brand idealtrucks 1967 - 1972 F-100 & Larger F-Series Trucks 11 02-25-2016 12:40 PM
No way to identify rebuild kit for AutoLine 2150 carb CelticOne 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-28-2016 04:08 PM
Help deciding which carb 76ClydeF100 1973 - 1979 F-100 & Larger F-Series Trucks 4 06-30-2015 07:49 PM
Carb replacement - carter YF knowledge sought hillcountryflt Ford Inline Six, 200, 250, 4.9L / 300 6 10-17-2014 08:22 PM
Tags
4300, 460, application, autoline, autolite, c857a, c8sf, carb, carbs, carburator, carburetor, ford, googleautoline, man, quadrajet, reviews, sale
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
