Need some advice on a Limited Slip.
aI am going to install a LSD in my rear end on my 02 with the 3.73 Open. Now, I have also heard of these putting additional stress on the rear, so some folks advise also adding a differential cooler, like a Mag-Hytec or similar. As for the LSD, I think I am going to go with a Truetrac, as it seems like many on here have had positive results.
My primary questions are:
A: How does the Detroit Truetrac do with snow and icy conditions?
B: Is the diff cooler needed? (I plow 7 hours a day or more when conditions hit, and the LSD will definitely get used a whole lot, not including my summer towing 4-5 days a week on a 4-6k lbs. trailer.)
Contact Randy's Ring & Pinion. Their tech support group comes highly recommended.
http://www.ringpinion.com/
x2 on contacting Randy's R&P. They have been excellent when I built my diffs.
I'm running a Eaton posi in the rear and Yukon Powr-Loc in the front of my rig. Both units work great. The rear unit is very quiet and locks up when needed and does not lock up when not needed. No need for the fancy diff cover. Just add some Limited Slip Additive with your fluid and it will be the best you will have done to your truck. Good luck.
I'd have to agree with you, in hindsight I wish I'd gone with a tru-trac, but hindsight is always 20/20. However I beat on my truck REALLY hard so we will see how long the Eaton lasts.
Still, if they do, and those clutches wear out, the True Trac should retain most of its function, I would think.
http://www.eaton.com/ecm/groups/publ.../ct_128482.pdf
Where I found this little nugget on page 5:
"* For TrueTrac models built with pre-load, the rotation will be restricted (approx. 100 lb. ft. torque required to rotate).
Pre-load units are all models for Toyota and Dana 30 axles, and for the Ford 9”–913A328 model only."
So it appears that some do have clutches. I knew I had seen that somewhere. Why they would put them on some, and not others, I don't know. Personally, I would prefer clutchless, but I guess when the clutches wear out you still have a limited slip.
whattatruck250
1999 to 2016 Super Duty
06-29-2009 09:47 AM
Gage2502
30
04-16-2008 11:46 PM
