6 Volt to 12 Volt? Gauges??? 1951 F1
There are a number of threads about this subject here on FTE.
Also, look on e-bay as there are Dakota Digital Gauges for the 51/52 trucks all the time. Here is a link to some:
http://cgi.ebay.com/ebaymotors/1951-...=p4506.c0.m245
Here is an online catalogue for Auto Meter Gauges :
http://www.autometer.com/cat_gaugeseries.aspx
If you want to keep the stock look and convert your Temp and Oil Pressure to Mechanical, I have a gallery that shows how to do it step by step, and it talks about gauge sizes. The stock amp gauge will work fine as is with the 12 volt system, however with the negative ground, you have to run the wire through in the opposite direction. The gas gauge will require a voltage reducer as the gauge and sending unit are matched - you can not use a 12 volt sending unit with this gauge - you have to use the reducer and th estock sending unit, and they work great together.
Lastly, here is a complete thread about wiring in the gauge adapters for the 51/52 instrument panels complete with pictures and drawings....have fun:
https://www.ford-trucks.com/forums/8...12-volt-2.html
jes26201
13
07-29-2012 01:16 AM
51phil
04-25-2011 01:19 AM
panningbros
07-09-2010 05:56 PM
