Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-06-2009, 12:25 PM
dr.ron dr.ron is offline
dr.ron is starting off with a positive reputation.
no clutch pedal, whining noise, extremely hard to shift
2003 F-150
4.2L
140K
stick shift
For about 1500 miles, my truck has been substantially harder to shift than normal. Today, while on the highway, it began making a high pitched whine - much louder in lower gears. Now, it is nearly impossible to shift...any ideas?
  #2 (permalink)
Old 09-07-2009, 12:14 PM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
Could be syncronizer(s) or most likely the clutch is worn beyond limits.Another possibility is a weak Clutch Master Cylinder.Im not familiar with Ford Standard trannys,but must assume todays trucks have Hydraulic Clutch activation.
This being the case,check the fluid level in the Clutch Resirvoir,and if its normal,you might want to "Bleed" the line that goes from the master to the slave cylinder.This is accomplished just as it would be if you were doing brake bleeding.
IF the fluid system is good..no air in the line,and the slave is moving the clutch arm properly,you have a worn throw-out bearing,clutch assy, or a combination of both. My syncronizer theory probably is not a factor,but bears keeping in mind..
__________________
Air Transport Radar Tech
  #3 (permalink)
Old 09-08-2009, 12:00 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE.
Good advice above.
Hydraulic master cyl at fire wall and slave cylinder on transmission. Check fluid level.
If all looks OK external, then suspect clutch/throw out bearing and then transmission internals.
If you can, put it in 4th gear and cruise along at mid RPM levels, find the RPM range where it is starting to make decent power, then gas it hard. If the engine revs and the truck doesn't speed up, then you have a worn out clutch assembly.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #4 (permalink)
Old 09-10-2009, 10:30 PM
Hey folks,
Thanks for the responses - much appreciated. I took it to a tranny shop, and the problem ended up being a broken slave and a worn clutch disk/pressure plate. Shifts better now than it did when it was new!
Tags
99 , clutch , f150 , ford , hard , harder , hydraulic , make , noise , pedal , problems , shift , shifter , slave , truck , whining
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
