P0401 obd2 code help!!! I've tried eveything!
Please help. I've had a 0401 code on my truck for the last two years. I've replaced the EGR valve and the dpfe sensor a couple of times, with fomoco parts. Ive also cleaned out the egr tube that comes off the exhaust manifold. In this time I also discovered a couple of vaccum leaks and replaced those. I changed the pcv valve, tried running 93 octane gas, and had a mechanic friend run a special smoke through the vaccum lines to find more leaks. Also put a brand new gas cap. I have an obd computer and cleared the code repeatedly but the light always returns. Some one please help or have an idea???
Thread Moved to the '97-'03 F-150 forum
from... '09-'10 F150 forum.
Welcome to Ford-Truck Enthusiasts!!
Based on looking at your profile I moved your thread here. In the future you may want to include your year/model/make and engine size.
I'm pretty sure the guys in this forum could help you out with the code that your getting... Good Luck!
The line that runs from the DPFE sensor to the throttle body is likely blocked.I suggest removing the throttle body and cleaning all ports forward,and AFT of the throttle plate.The Original DPFE modules were made of a metallic substance,that was prone to corrosion in the exhaust stream.This is a combination of carbon,and water.The newer sensors are plastic,and seem to resist this corrosion.
What's the purpose of the throttle body when there is two fuel rails (one on each side of motor) and 8 individual fuel injectors? And I just checked there are no lines coming off the dpfe going to the the area where the throttle body should be. The two lines go the the egr pipe which in turn ties into the exaust manifold(drivers side).
I did take off the throttle body. I did find that the two ports were 80-90% clogged. I reassemembled everything. I thought I had fixed eveything, and got a good 70 miles on the truck before I got the check engine light again. I have a obd2 code reader, and of
coure it's that 401 code again. I have a 98 ford truck, 4.6l, fixed all vaccum leaks, replaced egr valve and dpfe valve twice with fomoco parts. Cleaned out all ports on the throttle body. Any other ideas guys. This has been a two year problem and I'm about ready to buy a chevy just out of spite. I've got a 69 rag top, 71 Mach 1, and gran Torino dont make me go to the dark side.
Yes sir. I cleaned out all the ports to a high shine. The looked brand new when I got done. It took me a good couple of hours. And on the dpfe one hose seems to be slightly bigger. As is on the egr tube that to the exaust manifold. I got the top tube onthe egr tube going to the connection closest to the fire wall and the other below it going to the connection towards the front of the motor. Just out of curiosty... What color is the vaccum tube going to the egr valve itself? I'm willing to try anything at this point. I got and inspection coming up this month, All ideas are welcome. They won't pass it with a check engine light on.
