Recall 05b27 ??
Recall 05b27 ??
So I take by truck to the dealer having found a pool of tranny fluid on m garage floor. The tech says there is a hole in my transmission case and replacement cost is close to 4k. Ugh...... Naturally I research the net and find there has been a recall on that exact transmission for the exact same problem. I call FORD, nothing "pay for the repair and if there is a future recall we will reimburse".......sure thing buddy. The build date falls in line with the recall parameters but it does not show up on the "oasis" What can I do next? thx
2004 f 250 6.0 lariat. No plow package from the factory but I do plow with it.
This is what I have found
Diesel Technician Society
2005 Ford F-350 Superduty Automatic Transmission Complaints
WOAH, does this apply to all 05's, or just 05s with snow plows, if this affects my truck im gonna get looked at before this happens.
BTW, ive never heard of this TSB, i even put my vin in on fords recall website to see if anything came up when i first bought the truck, nothing
probably a tsb. Ford fixed them for trucks they suspected would be shifted into reverse alot (plowing). once they were fixed ford no longer cared to expand the tsb. My question is has this happened to anyone else? will ford meet me half way on a repair? it is very obvious that all of these transmissions are subject to failure from within.
Secondly, what is the solution. the dealer says 4k..........is it the same junk tranny? unable to rebuild due to hole in case.
Same thing just happened to my 05 F250
getting it fixed at a local shop
Here's my take on it
Ford knew the snap ring would eventually pop on all these transmissions
but it would show up first on 'plow trucks' because they are doing more forward - reverse shifts
so the contact the plow trucks and fix them (reduce busted case replacement warranty cost
everyone else
screw em, we can make more money selling them rebuilts after their warranty expires
google Pinto rear end crash fire
Ford figured it was cheaper to pay of the law suits to the burn victims than fix the gas tank hazzard
Yeah, I'm pissed
everyone else
Yeah, I'm pissed
This is where a third successful fix had been devised -- a rather simple plastic insulator fitted on the differential that would keep the bolts from ever making contact with the fuel tank. Cost of this item was less than $1.
Several company memos presented as evidence during the civil trials revealed that these remedies were discussed, with the conclusion that to shut down production and retool would be too expensive. Most damaging to Ford were memos found and published by author/researcher Mark Dowie in the muckraking magazine Mother Jones that detailed a cost analysis of corporate liability in the event of having to compensate crash victims.
Experts calculated the value of a human life at around $200,000, while a serious burn injury was worth about $67,000. Using an estimate of 180 deaths and 180 serious burns, someone put on paper that the cost to redesign and rework the Pinto's gas tank would cost close to $137 million, while possible liability costs worked out to around $49 million.
HowStuffWorks "The Pinto Fire Controversy"
got2bjoester
Escape & Escape Hybrid
25
05-03-2019 03:49 PM
edtahaney
2015 - 2020 F150
05-13-2015 11:00 AM
edtahaney
General Automotive Discussion
04-29-2015 11:47 AM
