Dumb Question... First of many
I'm not sure if this will help with your truck but on the '48-52 I've had I removed the few bolts that hold the entire front clip onto the truck, remove the clip as one piece and flip it upside down and go at with first a six point socket, then if that doesn't work I go for either an angle grinder or torch to cut the nuts off of the bolt. Rarely, very rarely, have I ever been able to just unbolt the fender bolts. It's a lot fast the other ways.
ditto what everyone else said above. flip front clip over and torch anything that does not twist off quickly.
I found a 52 at a local pick and pull this spring and you can't torch anything there so I was lucky to get most of the fender bolts to just twist off, a few are hard to reach and gave me a little trouble but I got lucky with getting them off. I was thinking I would get all but 2 bolts and have to leave them behind but I guess the planets were aligned that day LOL I only bloodied a couple knuckles too
good luck
good luck
I used a 3/8 rachet/ six point socket, tightened (clockwise), broke those suckers off, and removed the rear fenders in a few minutes. Only the back bottom bolt was so rusty the inside rotated. Visegrips did the trick. Just a few bolts and whole front end comes off. I found this on a previous thread. Someone needs to write a tips book/manual. I have found the best internet suggestions are on FTE. chuck
No dumb questions on here .Maybe some smart a@# answers every so often .Remember all of us were beginers on this Early Ford truck stuff at one time . Rusty parts are just one of the items you just accept while working on these old beautys .I had some front end nuts turn off with just 2 threads left on the nut .Won't break of when you need them to .Am dealing with some rust issues on certian parts of the stock '52 build .Blasting ,priming & painting the seat back & bottom frame was a real treat .
