Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Bio-diesel, Propane and Alternative Diesel Engine Fuels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 09-03-2009, 03:59 PM
binuya's Avatar
binuya binuya is online now
binuya is gaining momentum as a positive member of FTE.
Use of copper in a processor.
I thought I'd throw this question out in this forum, knowing there are some 'guru's' here on the subject of biodiesel processing. By the way, I've posted this same question on another biodiesel forum without any definitive answers.
I am in the process of making another processor, and ideally would like to use copper tubing in the plumbing. My main reason is to enable me to create a more compact, cleaner draining, and tidier system. It's a 55 gallon drum set up, and I do a single stage process with KOH. I also use the same processor to spray dry the bio with heat, so after it's done in the wash tank, it gets transferred back to the cleaned processor for drying.
The reason I even considered using copper was after seeing pictures of Graham Lamings processor. He uses copper in the plumbing, so one would think that this is ok. However, when it was brought up on another forum, most of the responses were that it should not be done. It was never adressed, however, how Graham was able to get away with it and I would think that if anyone knew what they were doing it would be him.
Any and all thoughts on this would be appreciated.
__________________
Alvin
2001 F250 CC SB 4x4 Lariat
6637, MBRP 4" Turbo Back, HPX, AIH Delete,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard
Homebrew American Biodiesel (B100 whenever I can)
  #2 (permalink)
Old 09-03-2009, 08:49 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
Biodiesel Guru
fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold
I've used copper and brass for years and have not noticed any problems. LONG term STORAGE in copper might corrode some of the copper away, but if you drain the system on a regular basis I don't see any problem.
__________________
Don.
Oregon Chapter Leader: To join the Oregon Chapter, click HERE
  #3 (permalink)
Old 09-04-2009, 02:28 AM
binuya's Avatar
Thanks Don, I was hoping you'd chime in on this. I think I will move forward with plumbing my new processor with copper.
__________________
Alvin
  #4 (permalink)
Old 09-16-2009, 09:07 PM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason is starting off with a positive reputation.
The fact is copper accelerates polymerization in VO and biodiesel. While it may not pose a noticable problem for some, avoiding it in your design would be best. Aluminum tubing is cheaper and has almost no effect on VO/bio-d. (I use compression fittings etc commonly used on copper)
__________________
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, LSD, 4.10's. (4) Dipricol Optix gauges, DP-Tuner F5, 6637, Swamps single-shots, 255/85/16 M55's!, DIY SVO system, more...
2000 Excursion, Limited Edition, 4x4, 7.3 - Frybrid/V3 VO system w/Frybrid 38 gal under-truck tank. www.frybrid.com
  #5 (permalink)
Old 09-16-2009, 09:56 PM
binuya's Avatar
Quote:
Thanks for your input. It's greatly appreciated. Since copper is so widely used in the UK, I figured it would be ok. I've even seen entire processor tanks made of copper. Turns out many of the water heater tanks across the pond are constructed with copper.
Anyway, with regard to the polymerization issue, I produce bio for myself (and some for my dad too), and make fairly small quantities (45-90 gal./month), so none of it sits for any longer than a month to 6 weeks. My thinking here is that any effects of polymerization would be fairly minimal.
__________________
Alvin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
