How much should a FICM replacement cost - Ford Truck Enthusiasts Forums
Old 09-03-2009, 12:55 PM
Andre the Giant Andre the Giant is offline
Andre the Giant is starting off with a positive reputation.
So I just got a call from the shop stating that the FICM is bad and needs to be replaced. What am I looking at for cost?
Thanks in advance
Old 09-03-2009, 01:00 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
FICM= $600+200 labor to install and flash = $800??
Old 09-03-2009, 01:44 PM
ljutic ss's Avatar
ljutic ss ljutic ss is offline
ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.
But don't be surprised if you get a $1,000 bill.
Old 09-03-2009, 03:48 PM
IMHO 800 is riduculous, but most run 12-1500. warranty recoup costs.
Old 09-03-2009, 05:37 PM
adambomb's Avatar
adambomb adambomb is offline
adambomb has a good reputation on FTE.adambomb has a good reputation on FTE.
Quote:
yeah that's what i was thinking too. i forgot exactly how much it cost me but it was about $1,200 or maybe $1,400. either way it's a lot of money man.
Old 09-03-2009, 05:45 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Quote:
Thanks in advance
A more accurate cost would have been to ask the shop while they were on the line.
Old 09-03-2009, 05:47 PM
adambomb's Avatar
that would have been a good idea
Old 09-03-2009, 05:55 PM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is offline
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
If I send npccpartsman out for beer they usually are free. His truck won't run when he gets back but hey...money saved is money earned.
Old 01-06-2010, 01:04 PM
berick's Avatar
berick berick is offline
berick is gaining momentum as a positive member of FTE.
Thanks in advance
My truck has been acting up a bit and I am thinking it could be the FICM. My issues began by not starting as good as usual in the colder weather. Today it was -20 celsius here (and I forgot to plug in), usually my truck moans a little at this temp but it will still start, however today it didn't. So I plugged in the truck for 2 hrs, and turned on my Espar heater and got the coolant temp up to 140 farrenheit and the truck turned over the first 5 times and it wanted to start but it was like it had no fuel. I finally got it to start and it would idle a little lower than usual and when I put it in drive I got absolutely nothing.... just idle. I turn it off and it is slow to start. What do you think? Does it sound similiar to what yours was doing? Thank god I paid the extra $$$ for extended warranty or I would be paying a tow bill and major repairs by the sounds of it. So what did it cost for a FICM? Was it arounf the $1,000 mark?
Old 01-06-2010, 03:03 PM
utjer utjer is offline
utjer is gaining momentum as a positive member of FTE.
I would have your batteries checked. If they are low it could cause all kinds of start up issues. Best thing is that it is free to have them load tested.
Old 01-06-2010, 03:09 PM
DrQuad's Avatar
DrQuad DrQuad is offline
DrQuad is gaining momentum as a positive member of FTE.
If it was still working it may only need to be resoldered DIY.
http://www.ford-trucks.com/forums/90...procedure.html
Old 01-06-2010, 03:23 PM
pgjeepster pgjeepster is offline
pgjeepster is starting off with a positive reputation.
I got mine done about 2 months ago 600$ for the part and 108$ for the re&re and flash.
Old 01-06-2010, 04:21 PM
berick's Avatar
Quote:
Batteries are good. I topped them up with a trickle charge and it turns over fine.... the starting and running are the issues.
Old 01-06-2010, 05:35 PM
jeffmfly1's Avatar
jeffmfly1 jeffmfly1 is offline
jeffmfly1 is starting off with a positive reputation.
ficm
I had mine replaced 2 months ago. It was free though ford if you are under 100K mileage. I didnt even have to pay the $100 deduc since it was emissions related.
Pretty much the same symptoms though. Very hard to start and when it did start it ran like crap and smoked until it warmed up then it acted normal.
ficm replacement,tune removal spoolmonster 6.0L Power Stroke Diesel 4 02-07-2017 10:57 PM
FICM Eppig 1999 to 2016 Super Duty 4 06-03-2016 07:48 AM
FICM Blueblood4evr 6.0L Power Stroke Diesel 15 07-18-2014 12:43 AM
FICM Flash mhatlen 6.0L Power Stroke Diesel 3 04-29-2012 12:32 AM
FICM Grommets 2003 EXCURSION 6.0L Power Stroke Diesel 10 11-04-2011 01:01 PM
Tags
03, 05, 2003, 60, 60l, cost, deisel, diesel, f250, f350, ficm, ford, powerstroke, prices, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
