oil pressure gauge fluctuation
well I will say this, the oil pressure gauge on our trucks is not a pressure gauge at all but is more of a glorified idiot light. (on/off) I was very disappointed when I found this out. I would check the electrical connection to the oil pressure sensor. the 7.3 requires high pressure lube oil in order to fire the injector so if your engine is running, its got oil pressure. I wouldn't worry too much about that gauge. if you really want to know oil pressure I would install a mechanical gauge.
1997, 73, 73l, driving, f150, fluation, fluctuates, fluctuating, fluctuations, ford, gauge, high, oil, powerstroke, pressure, sensor
