Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 09-02-2009, 10:13 PM
SDJHAWK SDJHAWK is offline
Garage is empty, add now
SDJHAWK is starting off with a positive reputation.
2008 Exp Radio Swap
So I bought a 2008 Exp. EL with nav and I have a button for a phone, but no blue tooth. I noticed that the 2010s have blue tooth and a number of other sweet functions and since I do not want to buy another Exp right now I was hoping to be able to swap in a '10 radio unit. Does anyone know if this is possible? If it is possible, does anyone know what wiring I need to change, if any, and where I can get the wiring and radio? Thanks for all of your help!
  #2 (permalink)
Old 09-03-2009, 05:31 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
That would require adding the Sync module too and I think that it would be very costly.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 09-04-2009, 11:29 PM
I figured that it would cost, but certainly not as much as a new truck. What I am wondering is if it can be done with the 2008 wiring harness or do I need another? Do I need to be splicing wires or is this a plug and play type addition using the existing harness. I know that the mounts are the same and that Ford switched to this all in one radio pack for the purpose of being at least partially interchangable. Since my tech guys at the local dealership are less than helpful, I was hoping that some enthusiasts had tried the swap. Please if anyone has some information I would love to hear it.
  #4 (permalink)
Old 09-07-2009, 05:21 AM
slc10844 slc10844 is offline
slc10844 is starting off with a positive reputation.
Check the "Ford Parts Direct" web site. It shows a bluetooth set up for your vehicle for about $400. Also requires a cable adapter.
__________________
2013 Explorer Limited
87 Ranger, XLT
  #5 (permalink)
Old 09-17-2009, 07:35 PM
heymrdj's Avatar
heymrdj heymrdj is offline
heymrdj is gaining momentum as a positive member of FTE.
heymrdjlive
Didn't somebody post about this once already? I think it was in the 09 F-150 forums. I think for the dealer to switch you out to a SYNC system is 1,500$ if I remember the thread right.
__________________
2004 Expedition
Eddie Baur 4x2
5.4L 2v Triton V8
NEW: 2 3/4" pipe with Flowmaster Super 50 Delta Flow Muffler and 3.5"x18" echo tip WOOT
Upcoming:
Dual 16" Troyer performance fans
WAAG grill guard
Scanguage II
all corners air suspension
  #6 (permalink)
Old 09-18-2009, 02:01 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
You cannot retro-fit the Sync module to a 07/08 model...and only some of the 09 models can get it.
There is something in the wiring itself in the dash. It may physically bolt in there, but Ford changed up the wiring in all of their 2009+ vehicles. The Expy got that change partway into the 2009 production round. Early build 09's are screwed.
it gets even worse if you have the NAV. The Ford accessories website specifically excludes Nav equipped vehicles...for the reasons listed above.
sorry to be a buzz kill man
If you want a integrated "Sync"-like radio to work with your phone & Blue-tooth, you need to go with the aftermarket.
JVC makes an awesome unit for about $650. Touchscreen DVD player, Nav Capable, Integrated bluetooth, integrated iPod/iPhone control, Dual Zone Audio outs. I had bought one a few months back, but never recieved it due a S/H dispute on eBay. I plan on trying again in 2 weeks.
however...always one of those isn't there?
if you have the steering wheel radio controls, you have to buy a $50 adapter. the OEM buttons won't automatically work...but they do work 100% with that adapter
KW-AVX820 Double Din Headunit
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #7 (permalink)
Old 09-18-2009, 02:03 AM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
Quote:
$550 installed for the Sync-Add-On module. Only for select 2009+ Ford vehicles though.
My Stang qualifies for it...but I might just put a Double Din in there instead since it's almost the same $$$...and I don't have to let some idiot Dealership tech near my car
__________________
  #8 (permalink)
Old 09-18-2009, 10:33 AM
berry1234's Avatar
That is a nice radio Tylus. The only problem I have with most aftermarket radios is they don't have time correction to move the sound stage in front of the driver. The OEM has the driver seat DSP which cheats this in a way, but sounds much better that a unit without it. Alpine and Pioneer use to put this in lot of units, but I see less and less of them.
__________________
  #9 (permalink)
Old 09-22-2009, 08:23 AM
doc40 doc40 is offline
doc40 is starting off with a positive reputation.
Same question
SDJHAWK, I have the same exact questions and concerns. Why do I have a phone button on my 08 Expy Navigation that doesn't work? I took it to the dealership and asked if I can get this programmed to connect to bluetooth and received the "deer in headlights" look.
To me, I would think the dealer could "activate" the phone feature but I cannot find any info about it. Dealer suggested mobile ease, but again I'm not to sure what it is. I can't understand why I would install some other phone feature when I have a "phone" button on my Nav unit.
Can anybody help and provide more info on either feature?
  #10 (permalink)
Old 09-22-2009, 10:11 PM
fire3110's Avatar
fire3110 fire3110 is offline
fire3110 is starting off with a positive reputation.
i have an 08 Expo EL with the in dash 6 CD changer. I would be interested in your Navigation system if it will work in my Expo. does anyone know if the swap would work?
  #11 (permalink)
Old 09-23-2009, 12:20 AM
david_jr david_jr is offline
2008 Ford Expedition
david_jr is starting off with a positive reputation.
According to the manual in my 08 Expedition, the phone button is really just a mute button that mutes the audio system when you push the button so you can talk on the phone. This doesn't work in mine though. Push the button and it does nothing.
  #12 (permalink)
Old 09-23-2009, 09:45 AM
yes, I read that in the manual too, but I figured it was an adapter that the dealer could put on upon request. That's what I get for assuming.
After some thought I have decided to go aftermarket to install the features I want such as backup camera, bluetooth, DVD functions, and a couple others.
So far I am lookin at this HU. Any thoughts or suggestions?
http://mobile.jvc.com/product.jsp?mo...hId=126&page=1
Tags
2004, 2008, 2010, dont, expedition, ford, forums, install, lights, radio, sdjhawk, swapping, sync, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
