Go Back   Ford Truck Enthusiasts Forums > Misc. > Oil and Lubrication
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Oil and Lubrication NO MLM Dealers, Wholesale Buyers Or Retailers allowed (except sponsors)
SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 09-08-2009, 07:10 PM
pawpaw pawpaw is offline
pawpaw has a good reputation on FTE. pawpaw has a good reputation on FTE. pawpaw has a good reputation on FTE.
If your not certain it's pre-oiled good enough, you could also disable the fuel pump so it won't function & have the injectors wet the cylinder walls down & so the engine won't start.
Then crank the engine with the starter motor, to make sure the oil pump is primed & to build oil pressure.
Don't crank for more than 15 seconds, so you don't over heat the starter motor.
This will do a pretty good job of building oil pressure & pre-oiling the engine.
If you do it with the spark plugs removed, the starter will have an easier time of it, will build oil pressure quicker, as it'll crank the engine over faster.
If your really persnckety, you could squirt a little Marvel Oil into each cylinder before cranking the engine as it'll help lube the rings before starting the engine.
Replace the spark plugs, then re-enable the fuel pump & start it up.
More engine pre-oiling thoughts for consideration.
__________________
99 Ranger 4dr 4x2 4.0L 5spd auto 3.55L/S Payload pkg2 tow pkg
Details are trifles but trifles make perfection & perfection is no trifle
(Ben Franklin)
Our signature is a sign of a job completed autograph your work with excellence
  #17 (permalink)
Old 09-09-2009, 03:21 AM
johnboy427's Avatar
johnboy427 johnboy427 is offline
johnboy427 is starting off with a positive reputation.
The problems with just turning the engine over to prime it is you will wipe all the break in lube off your cam. If you really want to do it this way do it before you install the lifters and lash the valves.
-Johnboy
__________________
-1979 F-250 4X4 351 Cleveland 4spd
-1993 Probe GT 2.5L 5spd
-2009 Focus coupe 5spd Significant others DD
  #18 (permalink)
Old 09-09-2009, 07:48 PM
pjwoolw's Avatar
pjwoolw pjwoolw is online now
pjwoolw is gaining momentum as a positive member of FTE.
Good point!
__________________
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab (stock)
1986 F250 6.9 XLT Gone but not forgotten
  #19 (permalink)
Old 10-24-2009, 05:36 AM
Sport45's Avatar
Sport45 Sport45 is offline
<= Our '83 "Before"
Sport45 is starting off with a positive reputation.
Quote:
Originally Posted by TOPS View Post
Well got a scare, I was running the drill and the socket came out of the extension, Thought the socket lodged onto the oil pump shaft be cause I JB weld the socket to the extension, but the weld did not hold, I said a small prayer to the big man and got a new extension to try and retrieve the socket, well it came out. Thank the Lord! Pump should be primed!!
Were you running the drill in reverse? The one's I've primed (pre-lubed, actually) had counterclockwise distributer rotation. It takes a good bit of torque and I burnt up the first drill I tried to use for this. Now I use a speed handle taped to a 6-pt deep socket and let one of my sons turn it.
__________________
'00 F250, CC SWB 4x2, V-10.
'83 F100 SWB 4x2, 302 AOD.
<= "After"
Tags
351c , 54 , distributor , f150 , ford , install , oil , pre , prime , priming , pump , start , tool , truck , utube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
