Any tips to install Magnaflow 15755 on a '05 Expedition?
Greetings, my first post. Any tips to installing a new Magnaflow cat back exhaust #15755 on an '05 5.4 Expedition? I did a search and didn't see much. Looks like I would want to cut the stock exhaust pipe as close to where it starts to go over the half-shaft as possible in order to get it out easily rather than just cutting behind the muffler. How about installation? Best to let the right rear tire hang for additional clearance? I have a 4-post lift, but can probably only lift the Expedition a couple feet in the air (10' ceiling), but that would probably put the exhaust system 3.5 feet off the floor. I can then lift the rear tire off the runway to let the suspension droop. How long did it take you? Thanks!
Thanks. Yea, I already have the install instructions, was wonder about real-world installation, as it always looks so easy on paper. Interesting about the drone, virtually all other comments I've seen or heard suggest there is little to no drone. I'm looking for little to no drone, and relatively quiet for this daily driver. I have plenty of loud cars. LOL
Does your blower build any boost at low highway RPM? That could contribute to your drone. Both my Paxton cars seem to resonate at lower speeds more than my normally aspirated cars even using the same mufflers. Thanks!
carid
Vendor Specials, Discounts, Product Announcements & Group Buys
02-24-2017 07:27 AM
Venture1
12-05-2016 09:24 PM
EPI-911
09-29-2015 05:16 PM
Tungsten
09-18-2008 02:10 PM
15755, 2003, 2009, converter, drone, exhaust, expedition, f150, ford, forum, install, installation, installing, instruction, magnaflow
