During my search I couldn't find anything on the Readylift 2.5" fixed lift so I figured I would post some pics of the end result. So far I'm very happy with the lift and it clears the 35" Toyos great. Have some minor rubbing on the plastic fender liner at full left turn. But it is easily fixed by pulling it back with an included bracket. The thing I like most is that when I go back to the stock-sized studded tires (for towing in the winter) it still looks good.
Looks sweet! I really like the wheel and tire combo. How oyu like the v10, I had a couple 2valve v10's but none of the 3 valves, but am considering buying one. do oyu pull any thing with it?
I'm actually really happy with the 3v v10. My last truck was a Duramax LBZ and to be honest, I wasn't expecting much as far as towing performance from the gasser. After towing around 9,000 lbs. through numerous mountain passes I've got to say it is an animal. It needs to shift more than the 650 ft.-lb duramax did but it will pull grades at nearly the same speeds. It does drink more fuel but once the cost of diesel is taken into account there isn't much of an advantage anymore, compared to the new 6.4 at least.
