ECM Part Number - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
ECM Part Number
Old 09-01-2009, 08:53 PM
LeeroyDiesel LeeroyDiesel is offline
LeeroyDiesel is starting off with a positive reputation.
ECM Part Number
My ECM or PCM (assuming those are the same) is bad and I need to replace it. I've got a 2000 Ford Excursion 7.3l 4x4 automatic. I can't find out what p/n i'm supposed to use. I just need to order a new computer. Please lend a hand
Old 09-01-2009, 09:44 PM
wilbur996 wilbur996 is offline
wilbur996 is starting off with a positive reputation.
If your PCM is bad, you will have to remove it anyways. The part# will be on it. That is the only real way to get the exact part#. I guess there could be one part# for the year but I don't think it works that way.
Old 09-01-2009, 09:57 PM
It's a pretty simple removal and install correct? Just remove driver side tire, remove fender liner, pull out computer put in new right?
Old 09-01-2009, 10:52 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
Nope, not on a superduty. On the firewall by the drivers fender undo the nut in the center of the electrical connector for the ecm. Under the dash, there will be a plastic case around the ecm. Undo two small screws that hold that in and remove the pcm from under the dash.
Old 09-02-2009, 08:26 AM
The Injector drive module (IDM) is located in the fender area. The power control module (PCM) is located under the dash. Which are you trying to replace?
Old 09-02-2009, 08:53 PM
what does the injector module do. I did find the PCM, got the part number its the YC3F-12A650-AVA. Question though, when i contacted the dealers they all said the part number is YU7Z-12A650-AA. Anyone know what the difference is. I'm going to order the one that came out of my truck but just curious.
Also, apparently i have a chip in my truck, it doesn't look like a diablo but it definately is an aftermarket chip. What should I do with that. do I just plug it into the new one or don't even try it?
Old 09-03-2009, 06:07 PM
Not sure why you need a PCM as you did not say what the problem is you are having with your truck. First thing is to remove the chip and see if your PCM is good by installing back in the truck. Until you get your truck running correctly I'd leave the chip out.
The IDM (as I know it) take the 12 volt power and turns it into something like 120 volt power to drive the injectors. The PCM sends a signal to the IDM to open the injector. There are other things that happen but that is the basic explanation. The guys here know more.
ECM location James Law 1997 - 2003 F150 1 01-06-2016 11:18 PM
ECM Location Amish Ford 1997 - 2003 F150 3 12-04-2015 06:11 PM
BILLY BILLYBOB168 1987 - 1996 F150 & Larger F-Series Trucks 3 09-25-2014 12:37 AM
ECM wiring diagrams for Econoline 4.2 1999 fcopsr 1997 - 2003 F150 0 02-08-2014 06:59 PM
ECM location 94 E-150 TimLorentzen 1968-2013 Full Size Vans 3 03-29-2009 10:11 PM
Tags
2000, 2001, 2002, 73, diesel, ecm, f250, f53, ford, number, part, pcmecm, remove, superduty, truck, yu7z12a650aa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
