1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
6" Suspension lift, Tire size??
Old 09-01-2009, 01:22 PM
frdf250's Avatar
frdf250
frdf250 is offline
I am planning on getting a 6" suspension lift for my 2000 f250. i am trying to figure out if i should get 37" tires. will they fit. what would the max size be if i wanted to get tires for that 6" lift. i found this chart -
http://www.explorerprocomp.com/PDFs/07cat/130-131.pdf
but it said 35 was the biggest??
Old 09-01-2009, 01:59 PM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
I wouldn't put too much merit in that fitment guide. It says that a 2005-2007 Super Duty can run 16" wheels... wrong. It says that you need 2" lift to run 33" tires... wrong. I'm running 33" tires from the factory with stock suspension. Hopefully others will chime in soon.
Old 09-01-2009, 04:49 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
Depends on what you're doing with the truck. Hardcore wheeling is only going to fit a 35" in there without major rubbing. It may fit if your wheeling is limited. I'm running a 6.5" lift with 37x13.50 on 17's (Toyo M/T's) and have mild rubbing on full steering lock. I don't wheel like I used to but any rubbing I've ever had has been on the leaf springs.
By the way, I have a 6.5" pro comp lift on my '00 and it's garbage. I bought it like 5-6+ years ago though so I'm sure they've made significant improvements since then. At least I hope they would've.....
Old 09-01-2009, 04:56 PM
discojon's Avatar
discojon
discojon is offline
04 SuperDuty CC, 6 inch BDS All spring lift. I am running 37 13.50 17 Pro Comp Xtreme all terrains with moderate rub a full lock.
Old 09-01-2009, 05:34 PM
Meeks's Avatar
Meeks
Meeks is offline
Get 37" tires man! You'll regret it if you don't. Worst thing you will have to trim your valence. Besides those guys aren't gonna tell you a tire size that could possibly damage your truck in any way just to cover them.
Old 09-01-2009, 06:59 PM
frdf250's Avatar
frdf250
frdf250 is offline
good point man, everyones got there junk all caught up because of law suits. i think i am going to go with 36 or 37's
if i go with the 37's though im probally going to want an 8" lift though right?
Old 09-02-2009, 09:07 AM
2000silverbullet
It's a never ending cycle. With an 8" you can comfortably fit 38's.
Old 09-02-2009, 09:22 AM
SGnAZ's Avatar
SGnAZ
SGnAZ is offline
In another thread you posted that you had an 8in lift and wanted to put 38's on it?
Old 09-02-2009, 09:28 AM
frdf250's Avatar
frdf250
frdf250 is offline
Im in decisive. i bought this last night -
http://cgi.ebay.com/ebaymotors/ws/eB...6876&viewitem=
i had their 8" lift picked out, but realized it would look way to jacked up if i was driving tht around all the time.
Old 09-02-2009, 05:56 PM
Meeks's Avatar
Meeks
Meeks is offline
Hey what wrong with that!! Well what size you gonna try to put under it?
Old 09-02-2009, 08:37 PM
ash_flat_diesel's Avatar
ash_flat_diesel
ash_flat_diesel is offline
I just put that kit on a guys truck & I was not impressed with the quality.
Old 09-02-2009, 08:47 PM
frdf250's Avatar
frdf250
frdf250 is offline
explain pleaseee
Old 09-02-2009, 09:26 PM
ash_flat_diesel
Nothing big. Its just not the best. There were a few holes that had to be elongated to allow the piece to bolt up like the track bar drop bracket. He ordered a 4" & got 6" front springs. I had to use some old u bolts I had & stack 2 blocks to get him going for the night, till they could send the correct stuff.
Old 09-02-2009, 09:31 PM
frdf250's Avatar
frdf250
frdf250 is offline
dudee do not be telling me this stuff ha i am fanatic about my truck, this is the last thing i want. he got it on ebay?
Old 09-02-2009, 09:35 PM
ash_flat_diesel
Rough Country from Top Gun
Quick Reply: 6" Suspension lift, Tire size??
