We put in three tomato plants, planted in late June. They're doing well, despite the late start. I didn't get any cayenne peppers planted this year though.
__________________
Jason Kendrick
'70 F100 Custom 390/C6
'93 Mercury Topaz 2.3L
'99 Ford Windstar SEL
Tomatoes and peppers like hot, direct sunlight, and they like to dry out between waterings. It was just too wet for too long, not enough direct sunlight. My tomato plants started to rot out at the roots.
Did experience a new kind of tomato plant this year though. I bought what I thought were a few big boy tomato plants from an Earl May down the street. I ended up with a really strange tomato plant that puts out purpleish-green tomatoes. Had to research it on the net to find out they are called Black Tomatoes. Different tasting too.
__________________ Lisa Early '99 PSD long bed XLT supercab. 4" Pro Comp suspension lift, 315 BFG AT's on 17" Liquid Metal Gatlins, Hypermax Boost Pyrometer, 4" exhaust, DP Tunes - no start, 60 Tow, 80 Econo, 120 Race, 203* thermostat and billet housing, 6637 w/Pete's cover, CCV, oil crossover Kit.
Wonder if that isn't what happened to my mom's plants, they were doing pretty good, then just suddenly died, but the ground around there does tend to stay wet. The peppers had been doing pretty good as well, but didn't make a lot of them. My tomatoes weren't planted until at least June, and are faster maturing because they were so late, only in the last couple weeks started to get any from it, and they are small, but are likely the nature of Early Girls...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, NV4500 with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
i think we had beef steak tomatoes but they died off way early.our 8 sweet corn plants failed. we had 2 potatoe plants and the fruit they beared was sriveled up.
__________________
jack, slackmaster #7
1996 ford ranger xlt extended cab,2wd,4.0L v6,5spd,3.08 gears, tornado intake spacer, msd ignition,sun super tach2, k&n air filter, nascar oil filter.
__________________ *~*Tammie*~*TheOne and Only WeeVee Peepette "When it snows, you have two choices: shovel or make snow angels" "Getting an inch of snow is like winning 10 cents in the lottery." "Sex is like snow, you never know how many inches you're going to get or how long it will last."
Off to my Physics test for the day... heck of a way to start the day....At least I have the rest of the day off for a change, now just gotta get it to quit raining long enough near a weekend to get my water line run so i can get hooked up to rural water and stop having to haul it from my parents...
__________________
And here I am again, but today I go into work later, so I need to do a bit on my trailer so i can pick up a Lincoln that needs to be removed from a property in town. Have to see what it is going to take to get it out of where it is, then of course, what I can scavenge off of it....
__________________
It would seem the deal fell through, as my co worker never came in to let me know where it was and such. I'm not going to drive the truck and trailer in to see if I find anything out. 70 miles for nothing at 10 MPG vs 35 MPG is not good financial sense to me.
__________________
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
