No Power to fuel pumps - Ford Truck Enthusiasts Forums
Old 09-01-2009, 09:44 AM
lopitt85 lopitt85 is offline
lopitt85 is starting off with a positive reputation.
'89 F250, 5.8L, dual tanks
I was having an issue with the fuel pumps not pumping fuel, but I could hear the high pressure pump (brand new), and both low pressure (in tank pumps running. Verified each one by getting under truck and listening to the tank. So in the process of checking each pump I was following a tip suggested here to disconnect the high pressure pump's wiring, so as to not run it while dry, and verify that the back pumps are not only running, but are also pumping. So I disconnected the harness to the high pressure pump, and pulled the supply line for the back tank and stuck it in a bucket to catch the fuel. When I turned the key foward to power the rear tank pump, I heard a pffft (like a fuse blowing) and there was a little bit of white smoke under the hood near the battery/starter relay.
Now I get no power to any of the fuel pumps. Car still has power everywhere else. I can crank the car and it will try to start, but obviously it wont because no fuel is being pumped. The car has power everywhere except to the pumps. Where do I look? Starter relay is fine (I assume), as I can crank the engine from the key. Does the Fuel pump relay tie into the starter relay? Would a problem with the starter relay affect power to the fuel pumps? Where is the fuel pump relay? I swear I cant find it. I checked the fuses under the dash and they are all fine. I dont know where to look.
Old 09-01-2009, 10:01 AM
Neptoess Neptoess is offline
Neptoess is starting off with a positive reputation.
power distribution box drivers side under the hood behind your air filter. bunch of fuses and relays. check your manual to see which one the fuel pump relay is
Old 09-01-2009, 10:10 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Sounds like you had the wires to the high pressure pump shorted to ground.
What you did was burn open a fuse link "M" that comes off the battery side of the starter solenoid.
Just try pulling each one of the fuse links apart and the one that stretches is bad.
You do NOT have a "power distribution box drivers side under the hood behind your air filter".
Your fuel pump and EEC Power relays are in a row on the drivers fender.
Old 09-01-2009, 10:13 AM
subford's Avatar
By the way here is a wiring diagram if you need it:
Old 09-01-2009, 10:48 AM
Wow thanks for the quick responses. I think you are right. One of the fusible links is really stretchy. Do parts houses carry these or do I need to see a dealer or junkyard?
Thanks
lopitt85
Old 09-01-2009, 11:38 AM
subford's Avatar
Just go to auto parts store and buy a roll of 20 GA fuse link wire and splice it in about 3 to 6 inches with butt connector and a ring terminal.
Old 09-01-2009, 01:06 PM
Thanks. Repair done, power restored. Now I just have to drop the tanks and replace the pumps.
Old 09-01-2009, 09:11 PM
i have a box under my hood that is clearly labelled power distribution box. so does a buddy of mine with a 92 4.9L
Old 09-01-2009, 09:23 PM
subford's Avatar
Quote:
Yes you and your buddy do but the OP does not.
Old 09-01-2009, 09:24 PM
oh. they must have started it with the 92 model year then. sorry for my mixup
Old 09-01-2009, 09:54 PM
subford's Avatar
Yes I think 1992 was the first year for the box.
99' F-250 6.8L Fuel Pump Wiring question. Rhino99 Modular V10 (6.8l) 0 02-21-2016 07:11 PM
05' F250 No Start - Fuel pump not running? TruckBoatTruck 1999 to 2016 Super Duty 34 12-16-2011 10:27 PM
Trying to diagnose the two pump fuel system junkyardjeff Fuel Injection, Carburetion & Fuel System 1 11-01-2011 07:32 PM
86 ford 302 FI Fuel Pump Relay MikeFlorida 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 02-21-2007 10:27 AM
'95 Windstar fuel pump circuit electrical problem mattklionsky 1997 - 2003 F150 4 08-03-2001 12:00 AM
Tags
150, 1987, 49l, box, distribution, f150, f250, ford, fuel, power, pqwer, pressure, pump, ranger, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
