Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch, Transmission, Differential, Axle & Transfer Case
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-31-2009, 11:08 PM
julibird julibird is offline
Garage is empty, add now
julibird is starting off with a positive reputation.
Unhappy My Clutch won't bleed?
I don't know a lot about cars. Or trucks for that matter, but I'm trying to learn. I own a 2000 Ford Ranger. And I accidentally put fuel injector cleaner into my clutch reservoir about a week ago. I tried to bleed it today, but it didn't bleed at all. As if it were clogged maybe? My last resort is taking it to a shop, although I realize it will probably have to go. Any suggestions?
  #2 (permalink)
Old 09-03-2009, 11:46 AM
Mustang6147's Avatar
Mustang6147 Mustang6147 is offline
Mustang6147 is gaining momentum as a positive member of FTE.
Anytime you contaminate a hydraulic system, the results are never good... However my opinion is, I would have used a Turkey baster to suck the fluid out of the resivior, instead of trying to bleed it, all you did was, contaminate the whole sytem, istead of keeping it contained in the reservoir... Live and learn... I probably would continue to drive it, or suck the ressivoir dry, and refill t with the proper fluid... The brakes would have been another story. I would leave that to the oil change people to check
__________________
06 SuperDuty 4x4 extcb 5.4, TorqShift, 4:10.
90 Mustang 9's, 750 HP Windsor. Ultratech Chassis
http://www.youtube.com/watch?v=pibt-TVgAx4
40 GMC truck, Mustang II, SBC.
Sig Sauer P229 Two tone.
  #3 (permalink)
Old 10-02-2009, 03:22 PM
BigF350 BigF350 is offline
2000 Ford F-350
My Garage
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
adrian.erks.harris adrianerksharris
Thread moved to Clutch and Transmission forum where you should get better responses!
Best of luck and welcome to Ford Trucks!
Adrian
  #4 (permalink)
Old 10-03-2009, 12:56 AM
johnboy427's Avatar
johnboy427 johnboy427 is offline
johnboy427 is starting off with a positive reputation.
How are you bleeding it? I use a two person a approach, one person opens the bleeder and the other pushes the pedal down, then the first person closes the bleeder and the second lets the pedal up then the pedal goes down and the bleeder opens back up. Repeat until it works. Just thought I would throw the basic idea out there, because you mentioned your lack of experince. Welcome to FTE. Just wandering did it work fine before you tried to bleed it, if so I think it should work fine once bled properly.
-Johnboy
  #5 (permalink)
Old 10-03-2009, 01:13 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
1984 Ford Bronco
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
be glad you don't own a dodge... they dont have bleed screws...
spent longer trying to get air out of the external slave on my buddies 98 dodge 2500 than what it took to pull the tranny and replace the one in my '88.
back to the subject, i agree with a baster method, and then using the two person method. just make sure the person running the clutch doesn't stomp down too fast, you'll get a bath.
__________________
1973 f250 highboy 4x4
1984 full size bronco, -DIS, wide band megasquirted 300 and np435 w/ dual range aux tranny on the way! - finally updated! 12/29/2011
1988 f150 extended cab 4x4, mostly stock.
1984 mercury capri, 5.0 conversion, my little monster...
1961 ford falcon, all stock, in family since '68
Tags
1996, 2001, 250, 96, 97, bleed, bleeding, clutch, f150, ford, hydraulic, ranger, superduty, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
