You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
__________________ Ken
"Socialism, like the ancient ideas from which it springs, confuses the distinction between government and society. As a result of this, every time we object to a thing being done by government, the socialist concludes that we object to its being done at all. " -The Law, Frédéric Bastiat, 1850
Also, I was wondering about the exhaust coming out of the top of the engine. Seems like it's going to get pretty hot up there. I would think that in a conventional V8, air circulating up from below would keep things from getting too hot. But with all of the exhaust and the turbo on the top, covered by the hood above, and blocked by the cylinder banks on the sides, I wonder how they will keep the underhood temperatures reasonable.
I am not an automotive engineer or anything, this is just a gut reaction.
I'm sure the two cooling systems come into play with that. The hood looks to be taller as well. I'm sure to help dissipate heat.
From this article it seems as thought they are doing everything they can to make this as reliable as possible to avoid all the headaches of the later generation International diesel engines. I suspect though, that it will come at a high cost.
__________________
Mike - 2004 F-250 V10 CC FX4 SRW
Peak HP at 2600RPM? Torque at 1600 is good though. If it's gonna be a high RPM motor it may be tough to sell. A big reason to have a diesel powertrain is not having to make the transmission shift for every little hill or change in speed.
My 6.4 revs high enough for me. Listening to a diesel motor at 3000RPM's is not a comfortable feeling. I'll probably buy into it one day, I like my 6.4 so I guess my mind is open enough for what the future holds.
__________________
2011 F250 6.7 4X4 Lariat Ultimate FX4 3.55 ELock
Polk Audio component speakers, AFE Stage 7 intake
Sho Me Strobes, Shocker XL Horns, BakFlipG2
2 Kicker 10" subs, Rockford Fosgate amp
Ride-Rite air bags, VIAIR #10007 onboard air, AFE DPF back exhaust, power slot rotors/EBC pads, Nitto Trail Grapplers M/T 295/55 R20! Transfer-Flow 50 gal tank
Well, that all looks fine & dandy, and I have a fair bit of confidence that Ford is doing everything that they can think of to put the motor through its paces. But, the real test is going to be once that motor hits the streets in its production form. I will not say that it will make or break Ford, but it could be pretty damaging if its debut is marred.
__________________ Semper Fi
"Some people live an entire lifetime and wonder if they have made a difference in the world. Marines don't have that problem." - Ronald Reagan
It sounds like they've done enough testing to know they've got a good engine. I'm excited to see how it works out, and more than a little intrigued. Can't wait to see how the new turbo performs. (Although, part of me is secretly wondering how much room they'll have left for tuners to squeeze more power out of it without breaking parts. I'd be sad to not have the engine to play with - but I suppose there could be something to be said for not needing to mess with it....)
__________________
RoB
F250 2WD Crew w/ bigger torque converter, ISSpro guages
Recently installed: 6637 intake, MBRP 4" exhaust, Riffraff High Pressure Crossover, Garrett Power Max BB turbo, Stage 2 Single Shot Injectors and DP tuner. Thanks to Clay at Riffraff. The cup holders previously mentioned in my sig. are going to have to wait.
geez, can you imagine having to work on that thing ?
Apparently, it's supposed to be pretty easy to work on for a modern diesel. Unlike the 6.4L you won't have to lift the cab to work on the engines top end.
Quote:
If I had to guess, I would say this engine will definitely have more left in it than it's initial numbers will show. Two things give me this impression.
First, the emissions equipment on these new engines is numerous and very choking in nature. Once the after-market finds a way to get rid of some of it, we'll really get to see this engine open up to its full potential.
Secondly, the previous 6.4L was made to run on 40psi from the factory. This engine is supposed to be just as strong or stronger, and it's only running on 30psi from the factory. Me thinks Ford left themselves a little bit of breathing room, just in case the future Duramax and Cummins engines decide to step up their game.
