'67 F-100 Project
#51
Well, got bit by LMC. I bought an upper coil spring mount bracket from them, since one of mine had the bolt broken off in it, I figured I'd just replace it. Well, it wasn't made right, the spring is REALLY loose in it, dammit. So, brought the old one in here to work, to have the machinist drill it out for me. So much for getting anything else from LMC.
Edit: Guys here at work saved the spring bracket for me. Thank God for machinists!!!LOL!
#52
Pat sorry to hear that.
I guess they are just like any other aftermarket company where "all" parts need some fixing for proper fit. I know aftermarket fenders and other body parts are notorious for not fitting right out of the box. Did not know it went to suspension parts as well.
I ordered a window felt kit for the truck from them a few years back. It was supposed to be for both doors. I am one rattle kit short on the order. And it's to late to do anything about it now. I will just install it and get the missing parts.
And I need some more parts but don't really know where to go except for them. I am about ready to do a $150 order with them for some under hood weather stripping some grill screws & fasteners and a few other odds and ends.
Should I look else were?
#53
I've ordered stuff from NPD, and Dennis Carpenter with no problems. From what I'm told, DC makes the best body panels, so that where I'll get mine. I've heard all of the horror stories about LMC, but thought I'd try anyway.
Try these:
National Parts Depot
Dennis Carpenter
Obsolete and Classic parts
Mac's
Try these:
Dennis Carpenter
Mac's
#54
On my first quick look some of the nuts and bolts are only LMC so far (grill insert top and bottom screws - grill insert plastic filler nuts - headlight bezel screws - inner door handle nuts). Are they so bad that they could screw up these types of parts? I probably have the screws somewhere but right now it will be quicker and easier just to order new ones.
#55
Yeah, you'd probably be alright getting those. I'd just stay away from them for everything else. BTW, I called them, to see who makes their axles bearings, I was thinking of getting them from LMC, but they woudln't tell me. More than likely, they are imported (chinese), so I bought them locally.
