2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Console Removal
Old 08-30-2009, 08:05 PM
skytower31's Avatar
skytower31
skytower31 is offline
Console Removal
I'm trying to get my center console apart and I can't seem to get chrome ring around the shifter out. Is that required to get the main panel out around the shifter? I'm able to get the parts around the radio out no problem, but I'm trying to run a cable from behind the radio to the center console storage area.
Any suggestions would be much appreciated.
Thanks!
Old 08-31-2009, 10:33 AM
berry1234's Avatar
berry1234
berry1234 is offline
PM me with your email addy and I will send you the instructions from the manual.
Old 08-31-2009, 11:44 AM
skytower31's Avatar
skytower31
I don't seem to have PM privileges yet...
Old 08-31-2009, 11:54 AM
berry1234's Avatar
berry1234
ok, whats your email? spell it out so you don't get spam.
Old 08-31-2009, 11:55 AM
skytower31's Avatar
skytower31
jon broom field @ g mail No spaces obviously.
Old 08-31-2009, 11:57 AM
berry1234's Avatar
berry1234
Email sent. Let me know if you need anymore info.
Old 08-31-2009, 12:00 PM
skytower31's Avatar
skytower31
Much appreciated.
Old 08-31-2009, 12:06 PM
berry1234's Avatar
berry1234
No problem. The ring does come off. I would use a skinny blade wrapped in tape or similar so you don't scratch the finish.
Old 08-31-2009, 12:08 PM
skytower31's Avatar
skytower31
Email hasn't come through yet. Did you add the .com after gmail?
Old 08-31-2009, 12:23 PM
berry1234's Avatar
berry1234
Check now, I sent john...sorry. Should be there.
Old 08-31-2009, 12:32 PM
skytower31's Avatar
skytower31
Got it. Thank you.
I just can't get that ring off...I'm sure I'm going to break it. Even tried prying at it with a putty knife. May have to look for some alternate routing possibilities.
Old 08-31-2009, 12:49 PM
berry1234's Avatar
berry1234
It may not need to come off. Try taking the rest of the parts off first. I would assume the ring wouldn't cost a ton if you did break it.
Old 08-31-2009, 04:33 PM
08 Navigator's Avatar
08 Navigator
08 Navigator is offline
On my 08 Navigator, I pried up the woodgrain panel under the bezel with a putty knife and the chrome ring came off in one piece. I got the tip from somewhere out in internetland; I can't find it again, otherwise i would send you a link.
Open up the center console arm rest, and pry the trim panel up from the rear edge. The chrome ring comes right along with it. I struggled through all of this when I put a factory navigation system in my new 08. (The Nav system was from a 07 and it plugged right in and worked perfectly.)
Good luck with it.
Old 08-31-2009, 05:01 PM
berry1234's Avatar
berry1234
There are some bolts that need to be removed before you can pry it up. I believe the Nav console is a little bit different than the expy.
Old 08-31-2009, 05:20 PM
skytower31's Avatar
skytower31
The only bolt I can find is the one under the rubber storage area at the base of the stereo/HVAC vertical console.
Quick Reply: Console Removal
