Testing wheel speed sensor...how to ? - Ford Truck Enthusiasts Forums
Old 08-30-2009, 11:58 AM
mikren mikren is offline
mikren is starting off with a positive reputation.
I have a digital volt meter which also reads ohms but I have no idea how to test the speed sensor. How to, where to connect and stuff. I need some guidance on this one. 99 F150 4x4 Thanks.
Old 08-30-2009, 02:31 PM
Ok, I figured out how to test them.
The 2 front sensors are giving me 400 ohms each and it goes up a little as I spin the wheel.
The rear sensor reads about 1800 ohms and also goes up when I spin the wheel.
Is that about right ? Does this mean the sensors are good ?
99 F150
Old 08-30-2009, 05:04 PM
ok, now I'm a little confused.... Is the sensor that is mounted on the hub assembly the abs sensor or the speed sensor ? or is it both ?
Old 08-30-2009, 07:10 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
the pickup in the hub is the ABS. Some call it a "speed" because it measures the revolutions and compares to the other front wheel, and rear axle to compare and see if one is locking up, or slipping.
Old 08-30-2009, 07:18 PM
ah, thanks for clearing that up .what about those readings I got from them....is that about right and does that mean they're fuctioning properly ?
Old 08-30-2009, 10:23 PM
steve(ill)'s Avatar
i dont really know the resistance. wonder why the back one reads 4 x as much? could be bad, or maybe becasue the gear is 4 x larger? is this why you took it apart?
Old 08-31-2009, 01:09 PM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
You may need to use your low AC scale because they are magnetic field change sensing and produce a voltage output the module uses when the wheel is rotating.
Resistance is for general static measure to check for shorts and opens in the sensor and it's connecting cable.
How to test the EBPV sensor? clintusaf 1999 - 2003 7.3L Power Stroke Diesel 7 10-07-2014 02:43 PM
2003 Explorer Sport Trac abs sensor 1stbackfire Explorer, Sport Trac, Mountaineer & Aviator 2 04-18-2012 10:37 PM
Brake Stutter- ABS Sensor problem? zrt600guy Ranger & B-Series 4 02-14-2012 04:10 PM
Testing the P I P sensor Rackpatrol Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 08-02-2009 10:47 PM
Ebpv/ Ebpv Sensor Testing? vpofscc 1999 - 2003 7.3L Power Stroke Diesel 16 04-14-2006 01:22 PM
Tags
2000, 2004, 4x4, 99f150, abs, check, explorer, f150, ford, sensor, speed, test, testing, troubleshooting, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
