Who's Running HID's?
I'm running a kit from DDM tuning. The 35w system with 5000k bulb. Their kits are 70 bucks and include everything you need. I just installed them on my truck with no problems, only thing is I had to splice into the plug but I had a conversion pigtail with my 05 headlights so I never cut into the factory wiring. I love them so far, I got heads and fogs. Their also low beams only though..only down side. I'm trying to find out if they got a high/low beam controller because in their instructions they mention one, so that would be sweet... Let you know what I found out from them..
I will post some pics when I take some..
http://www.ddmtuning.com/index.php?p...=101&parent=85
mine are plug and play, xneon or somthing like that I think, 6000, love the color, its a bright white, doesnt have the bluish tint.
Hate the quality, cousin has the same ones in his SD, blink sometimes when comming on for about a min then will work right, and on my truck the passangerside doesnt always come on when the right one does. dont cheap put, but the good quality ones that run between 2 and 300 bucks, not the 90$ kits
But I know what you mean, mine does the same thing on the passenger side. It is worse now, I have changed out the ballast once and it got better, but now it's doing it again. I wonder why the right side is suspect? FWIW, I have them in my fogs too and they have been flawless, must be the wiring. I wonder if a harness upgrade would help. Even though the HID's aren't supposed to draw the same current, they may just be sensitive to the initial voltage drop. Must be the length of the wiring.
